Removed recirc blend door - Dodge Cummins Diesel Forum
 4Likes
post #1 of 27 (permalink) Old 07-11-2019, 07:54 PM Thread Starter
pocketgunner's Avatar
So the imfamous blend door. Well output in the cab for ac or heat was very low, could hear the fan ramp up but output just wasnt where its supposed to be. Took the blower motor out and of course the door right above it was broke and just laying there, so i just pulled it out. Re installed the blower motor and boom output from the vents is strong, changes to all the settings like its supposed to and even the defrost blows nice and strong now.
Just food for thought if those of you run into that particular door broke, i just pulled mine out with no ill effects it would seem. The rest of my blend doors work properly, knock on wood, and now you can actually feel the ac again.
2005 QCLB 6 speed - South Bend Single - Banks intercooler w/3.5" pipes and intake horn - Fast Coolers - Smarty Jr - AirDog 4G 165 - Longhorn Fab 90" traction bars - More goodies to come
SOLD-2003 QCSB 5 speed SDD3250-Fast Coolers-BMS 50s-6.7 feed tubes-CPP 115# springs-7/16" Manton pushrods-ARP studs-5" st8 Twin 7" CATs-ISSPRO's-Smarty S06-2nd gen manifold-He351- 2nd gen Intake Horn-Jacobs Brake-NUC Oil Bypass-Traction Bars
pocketgunner is offline
post #2 of 27 (permalink) Old 07-11-2019, 09:59 PM
vreihen's Avatar
My truck has worked fine for 10 years with the recirc door delete mod.....
2006 Ram 2500 SLT QCSB, 4x4, 6-speed G56 manual, VDO blower motor upgrade, panic button and recirc door delete mods, Diamond Eye 4" stainless cat-back exhaust, Tuson DirecLink OBD-II trailer brake controller, #JustSayNoToProdigyP3, #MirrorsDown
vreihen is offline
post #3 of 27 (permalink) Old 07-11-2019, 10:13 PM
So with the door gone is it stock on recirculate or fresh?
chargin72 is offline
post #4 of 27 (permalink) Old 07-12-2019, 12:19 AM Thread Starter
It works lol no I'm not exactly sure but I believe it will only bring in fresh air now. It won't recirc the air as it cant block off the outside input to circulate the cabin air.
post #5 of 27 (permalink) Old 07-12-2019, 01:44 AM
Run it how you want but the recirc door drops my temps about 8 more degrees in the cab. 30$ for a upgraded one off amazon that takes 45min to replace isn't too bad of a job.
2004.5 H.O. qcsb 2500. 5" straight piped, Smarty UDC, FASS 150, ARP studs, bag of parts, suncoast trans.
CumminUnGlued is offline
post #6 of 27 (permalink) Old 07-12-2019, 10:03 AM
So you are indicating one can replace the re circ door , without pulling the dash and then dissembling the hvac box ? Did not know
SOLD My 2001 and 2005 .
SOLD 2004.5 Sons mod truck
24hrsparkey is offline
post #7 of 27 (permalink) Old 07-12-2019, 10:50 AM
Yes sir. Do some research on google or youtube. Not a bad job.
post #8 of 27 (permalink) Old 07-12-2019, 12:24 PM Thread Starter
Yea I've seen the vids and threads on replacing it. I just never use my recirc in any of my vehicles, never have really. Actually rarely use my AC unless it's over 95 or long road trips and the wife and kids are in the truck. May eventually replace it, maybe not but for now it flows way more air which is what it was lacking before
post #9 of 27 (permalink) Old 07-12-2019, 12:24 PM
Did not know . Thanks
post #10 of 27 (permalink) Old 07-14-2019, 03:05 PM
5150eddie's Avatar
I did exactly the same thing when mine broke. Just pulled it out. I have never used recirc, my A/C has always been cold enough. Everything else works great. If something else breaks I'll fix the whole thing.
2005 2500 Laramie QC 6-speed 4X4 Longbed, Original Owner, Maxx Links, 17" FTE Resonator, 2" Levelers, Headache Rack, AirLift Bags, Hellwig Rear Sway. No camo, stacks, hi-po mods, or goofy stickers...
5150eddie is offline
post #11 of 27 (permalink) Old 07-15-2019, 12:16 PM
3 footin' through life
Broaner's Avatar
iTrader Score: 11 reviews
With Recirc door deleted its pulling from inside and outside. If you put some thick foil tape over the inlet behind the glovebox then it will be outside only.
'05.5 6.7 Shotpeened NV5600 - 12.6 @ 111.6 - 994 HP & 1630 lbs/ft
150%'s, LBZ/Arson pumps, MHP +1mm, ZZFab, Wagler Rods, 69/73/1.0 & s482
1350 Frontshaft, TruTrac, 315's, 64" T-Bars,TGC 1/2"+, Carli BJ's, '08.5
Street Triple, 103#/Extreme Pushrods, 625's Broaner Gets Hooked
Broaner is offline
post #12 of 27 (permalink) Old 07-15-2019, 01:54 PM Thread Starter
Will prolly do that at some point when I have some time
