Tipm? Maybe? - Dodge Cummins Diesel Forum
 2Likes
  • 1 Post By vreihen
  • 1 Post By vreihen
post #1 of 11 (permalink) Old 07-10-2019, 06:49 PM Thread Starter
Compensation_cummins's Avatar
Tipm? Maybe?
Ok I've got a 2005. I have a check engine light for an intake air temp sensor and a fuel rail pressure sensor. The iat is too high voltage and the fuel rail pressure sensor is just 'fuel rail pressure sensor performance'. I've cleaned all the fender well grounds, cleaned the connections under the tipm. Cleared the codes. Replaced the sensors. Checked EVERYTHING I can. Checked all relays. My truck will intermittently run like crap. Randomly maxing out at 20psi. When it's running over 20psi, it pulses between 30-35 psi. When it runs like crap it's almost like a cammed v8. At idle it just lopes. When I start driving it cruises fine. Sometimes it goes away and runs perfectly smooth. Can't figure out what makes it all Change. Brand new batteries and terminals. Sometimes I'll randomly throw a fan speed sensor code. My windshield wipers go haywire. On intermittent they'll go the speed of the current setting for about 4 swipes, then go full speed for like 9. Then slow back down. My stereo sometimes doesn't turn on. And my driver's front and rear speakers randomly go into 'limp mode'. They work but barely. Sounds like when you can only pressurize one ear on a plane. I've unplugged the tipm for an entire day and let the capacitors drain. Plugged everything up. And it runs perfect for like 2 days. Then boom. Whirlwind of crap again. I'm at a complete loss but the sensor signal codes are killing me. Any help??
Compensation_cummins is offline
post #2 of 11 (permalink) Old 07-11-2019, 05:01 AM Thread Starter
No one? No advice? Nothing?!
post #3 of 11 (permalink) Old 07-11-2019, 06:25 AM
vreihen's Avatar
I didn't know that the pre-CAN 2005 trucks had a TIPM.....
rghavana likes this.
2006 Ram 2500 SLT QCSB, 4x4, 6-speed G56 manual, VDO blower motor upgrade, panic button and recirc door delete mods, Diamond Eye 4" stainless cat-back exhaust, Tuson DirecLink OBD-II trailer brake controller,
, #MirrorsDown
vreihen is offline
post #4 of 11 (permalink) Old 07-11-2019, 06:32 AM Thread Starter
I believe thats what this is
ID:	851711   Click image for larger version
post #5 of 11 (permalink) Old 07-11-2019, 07:25 AM
rghavana's Avatar
2003-05 trucks have IPM, fuse box with attached FCM, one network serial body/engine control,
06+ have TIPM, 3 network redundant body/engine control.
If batteries are good best to pull codes from EMIC (cluster) and ECM to help narrow issue down.
04 QCSB HO Automatic
rghavana is offline
The Following User Says Thank You to rghavana For This Useful Post:
vreihen (07-11-2019)
post #6 of 11 (permalink) Old 07-11-2019, 07:26 AM
rghavana's Avatar
rghavana is offline
post #7 of 11 (permalink) Old 07-11-2019, 07:40 AM
PWong's Avatar
"Totally" is missing from the picture so not TIPM.
_________________
'05 2500 QC SLT SB 4X4 48RE Smarty Jr 180k miles
Baldwin FB1311 + Donaldson P551313 (3 Micron) + Baldwin PF7977
PWong is offline
The Following User Says Thank You to PWong For This Useful Post:
post #8 of 11 (permalink) Old 07-11-2019, 08:03 AM
PWong's Avatar
So you have two sensor DTCs that keeps coming back?
What's the pressure psi that you were talking about?
Check electrical connectors like those around the firewall and etc.
Check for degraded wiring like around fan clutch, near the AC comp area and etc.
_________________
PWong is offline
post #9 of 11 (permalink) Old 07-11-2019, 01:50 PM Thread Starter
I haven't checked fuel pressure. I don't have a gauge for it or a tool to test it. But the sensors are all brand new. Iat from Cummins fuel rail pressure sensor from Bosch. Still intermittent problems
post #10 of 11 (permalink) Old 07-11-2019, 05:42 PM
vreihen's Avatar
Is that really what the "T" stands for? Half of the people here (those who don't understand/appreciate technology) would argue that it really means TRAGICALLY Integrated Power Module.....
, #MirrorsDown
vreihen is offline
post #11 of 11 (permalink) Old 07-11-2019, 07:21 PM
Danderson's Avatar
Do the newer GM's and Superduty's use a form of TIPM? Just wondering if it's used industry wide?
'07 2500 SLT,5.9,Regcab.,G-56,4wd,Northstar TC800 popup 24/7. SBC OKHD. Dynatrac freespins and bj's. Synergy HD steering. Suspension mutt courtesy of Kore, Carli and Thuren.
Danderson is offline
