Molar fan clutch or other - Dodge Cummins Diesel Forum
 10Likes
post #1 of 49 (permalink) Old 07-01-2019, 11:52 AM Thread Starter
Need to replace the fan clutch. Itís not speeding up with the AC on, causing AC pressure to hit 450. Put a box fan in front of it and it stayed under 350.
Should I spring for the Mopar one? Are there reliable aftermarket options? Reliability is key for me. Iíll be towing my 5th wheel over 1000 miles from home in a few weeks.
2007 Ram 2500 crew cab, long bed, 4x4 5.9L, Firepunk EFI live and Towmaster 48re, Straight piped muffler, 2um Cat filter 10um water, separator on frame rail. Steering box brace
BRBurns is offline
post #2 of 49 (permalink) Old 07-01-2019, 12:16 PM
GRUNT 11B's Avatar
Go with OEM. These pickups have a tendency to not like aftermarket fan clutches and cause issues.
21gti likes this.
06 QCLB 4X4 G56, SOUTHBEND DD, FASS 150, ARP STUDS, 50HP INJECTORS, EFI, HE351 S475 COMPOUNDS, FLUIDAMPR, HAMILTON PUSHRODS & 103# SPRINGS, 624 HP 1090 TQ 01 QCLB 4X4 AUTO, WHEELS, TIRES, STEERING WHEEL, CUMMINS, BUMPERS, FUEL TANK, SEATS, ETC.
GRUNT 11B is online now
post #3 of 49 (permalink) Old 07-01-2019, 01:41 PM
Diesel 4 Me!!
21gti's Avatar
I bought one from eBay or Amazon. My check light came on after I installed it, couldnít remember the code. I bought OEM and replace it with NO issue.
I recommend staying OEM!!
Sent from my iPhone using Tapatalk Pro
06 2500 QCLB 4x4 Borla exhaust, Airdog2, Carli level kit, Torsion Sway Bar & ball joints, 08.5 Steering , Mopar steering box, S&B filter & Air Ram, Goerend Trans, Pacbrake Airbags, AMP side steps, Edge CT2!
21gti is offline
post #4 of 49 (permalink) Old 07-01-2019, 02:22 PM
utahtrapper's Avatar
If you want better reliability go mechanical with Strictly Diesel
https://www.cumminsforum.com/forum/3...ion-parts.html
https://www.cumminsforum.com/forum/3...an-clutch.html
2006 Blue Laramie DRW. 3500 5.9 G56 Mobil Delvac 50, Tans Cool PTO Covers, GDP Fuel Boss, GDP Double-X Ladder Bars, GPD big line kit, GDP MK-2 Fuel filter kit with CAT UHE 416 1225, GDP Power-Flo Intake Manifold, Throttle Up Industries Dual Fuel Filters, Dieselsite Coolant Filter, Cool Hose, Timbrens, 26k with Horses in Trailer, ................... BBi's .5 Towing Injectors WOW!
Carli Ball Joints
utahtrapper is offline
post #5 of 49 (permalink) Old 07-01-2019, 02:24 PM Thread Starter
Originally Posted by utahtrapper View Post
Iím considering this too. How long have you had yours? Any problem with the AC at idle?
BRBurns is offline
post #6 of 49 (permalink) Old 07-01-2019, 02:28 PM
2 years and AC colder than ever I also Gross 28k to 32k in the Mountains up some long steep passes Parley's, Soldier Summit.
Does it job Better than before
Carli Ball Joints
post #7 of 49 (permalink) Old 07-01-2019, 02:54 PM Thread Starter
Thanks. May go this route. I had seen other posts about it. I believe some of them were yours.
BRBurns is offline
post #8 of 49 (permalink) Old 07-01-2019, 04:34 PM
TECH SPECIALIST
steve05ram360's Avatar
Cerb mentioned the Hayden appears to have addressed their issues and is another acceptable option...
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 424k, HPTuners, G56, 25.065 mpg, mpg threads ->https://www.cumminsforum.com/forum/3...l#post23312562
steve05ram360 is offline
post #9 of 49 (permalink) Old 07-01-2019, 04:56 PM
Just like utahtrapper, I have the ford v10 mechanical temperature driven fan clutch, and ordered the adapter on Ebay, used the Mopar fan blades. It was unknown when I did mine if it would fit per the research that I have done. It has been flawless. But I don't tow nearly as much as I used to. In town stop n go driving with A/C on, or up a hill cause the fan to come on slightly, but have had it come all the way into lock up only a few times that I know of.
Search what we have commented on and posted about the fan.
04.5 CC SB 4x4, Low stall converter, billet input, intermediate, and valve body mods. HPT tuned by Firepunk, FASS 165 Titanium, BMS 50 injectors. Mechanical fan conversion with OEM plastic fan blades, Traction bars.
jballou is offline
post #10 of 49 (permalink) Old 07-01-2019, 07:24 PM
tryNto's Avatar
Do the Mod/Delete, almost 3 years and not a single complaint.
Also AC @ idle, better then stock ever was.
24hrsparkey and rghavana like this.
'03 QCLB 2500 305/555 NV5600 w/ FastCoolers 3.73 4x4, Color match Lear Topper.
Smarty S-06 PoD, Edge CTS for Gauges, DPP Cool Tube w/ OEM AF Box, Baldwin PF7977, GDP MK-2 FF Kit, Pusher Intake Horn, Adj. Boost Elbow @ 30psi, OEM Fan Clutch Delete/Mod, Steering Box Brace, On-Board Air w/Horns
tryNto is online now
post #11 of 49 (permalink) Old 07-02-2019, 10:03 PM Thread Starter
Bought the stuff to convert to mechanical. I hope I donít regret it, but it seems so much simpler. Btw, the Hayden mechanical fan was like $45 after shipping on amazon. Beets the hell out of strictly dieselís $190. This is far cheaper than the mopar clutch.
utahtrapper likes this.
BRBurns is offline
post #12 of 49 (permalink) Old 07-10-2019, 12:41 AM Thread Starter
I got all the new parts for the conversion. Got it all installed tonight. Everything went well. When I first started it up it was pulling more air. I was able to stick a dollar to the condenser. Then tried the air. It worked great for about 10 minutes. Then suddenly the air started acting up. The fan was pulling much less air; I could not stick a dollar to the front any more. Iím really confused. Could I have a bad mechanical clutch?
BRBurns is offline
