truck pulls to the left even after alignment - Page 2 - Dodge Cummins Diesel Forum
 3Likes
post #13 of 24 (permalink) Old 05-24-2019, 12:13 AM
trevdogg67's Avatar
What tires are you running? Sometimes tires can have a slight left pull
06 2500 qc 4x4 long bed, Dynamic 48RE, 4 TBE, s&b intake, leveled 35's, GDP 2 mic filter kit, thuren track bar, one piece driveline, redhead steering box, Carli ball joints, KMC Hoss 18s, EFI live, isspro EV2's, Detroit Tru-trac rear
trevdogg67 is offline
post #14 of 24 (permalink) Old 05-24-2019, 07:39 AM Thread Starter
pocketgunner's Avatar
I'm runnin 285/50R22 Nitto Ridge Grapplers, brand new
2005 QCLB 6 speed - South Bend Single - Banks intercooler w/3.5" pipes and intake horn - Fast Coolers - Smarty Jr - AirDog 4G 165 - More goodies to come
SOLD-2003 QCSB 5 speed SDD3250-Fast Coolers-BMS 50s-6.7 feed tubes-CPP 115# springs-7/16" Manton pushrods-ARP studs-5" st8 Twin 7" CATs-ISSPRO's-Smarty S06-2nd gen manifold-He351- 2nd gen Intake Horn-Jacobs Brake-NUC Oil Bypass-Traction Bars
pocketgunner is offline
post #15 of 24 (permalink) Old 05-24-2019, 07:43 AM Thread Starter
Here is the alignment sheet from Firestone.
ID:	848547   Click image for larger version
ID:	848549   Click image for larger version
post #16 of 24 (permalink) Old 05-24-2019, 07:49 AM
rghavana's Avatar
Good quality adjustable steering dampener, to get proper neutral setting, and then have shop follow this alignment guide
https://www.thurenfabrication.com/te...-handling.html
04 QCSB HO Automatic
rghavana is offline
The Following User Says Thank You to rghavana For This Useful Post:
pocketgunner (05-24-2019)
post #17 of 24 (permalink) Old 05-24-2019, 09:08 AM Thread Starter
So taking it to them this afternoon and going to have them set it to the Thuren specs and make sure the higher caster is on the driver side not the passenger to try and "Cross caster" it to take the left pull out of it. Caster I can do minimal changes to myself at home so that I am not totally worried about but I'm going to make sure they set total toe to as absolutely close to ZERO as they can. Right now its set at .2* total toe
rghavana likes this.
post #18 of 24 (permalink) Old 05-26-2019, 09:28 AM
Originally Posted by 98whitelightnin View Post
My truck was doing the same and I threw part after part after part at it and it still had the left pull. Turned out someone had put adjustable ball joints in and had the driver side adjusted wrong. Had the truck aligned twice and the alignment guys never mentioned it and the spec sheet didnt show it.
Exact thing as me
a-roddd14 is offline
post #19 of 24 (permalink) Old 05-26-2019, 09:57 AM Thread Starter
Well after taking back to Firestone and telling them to adjust to the Thuren specs its damn near perfect. Could possibly still use a little more cross caster but I'll deal with that when I put control arms on it. At the moment if your in the right lane shell drive straight down the road, left lane you have to keep the wheel slightly right due to the road pitch but it's much better than it was for sure.
post #20 of 24 (permalink) Old 05-28-2019, 07:13 PM
jdjonesiii's Avatar
I had a bad belt on a tire that caused me to pull to one side. A really good tire guy caught it. Take your spare and change left front tire and drive it. If still there do the right tire with the spare.
John Jones
Aiken, SC 29803
803 998 7424 cell
jdjonesiii is offline
post #21 of 24 (permalink) Old 05-29-2019, 07:31 AM
gsfitzsr's Avatar
Good idea above about rotating your tires. You might want to swap the two front tires around and then drive it. Some radial tires will cause pulling and directional tires can be even worse.
2018 RAM 2500 CTD 68RFE
RV Grand Design 303RLS
gsfitzsr is offline
post #22 of 24 (permalink) Old 05-29-2019, 12:20 PM Thread Starter
Problem is my spare is a smaller size, havent swapped it to the right height tire yet, and the ridge graps only have about 1000 miles on them so dont think itd be a bad tire
post #23 of 24 (permalink) Old 05-30-2019, 09:11 AM
ltrcummins's Avatar
maybe!!!
Originally Posted by b.lee View Post
It probably pulls right when braking due to a bad brake line (partially collapsed) or bad caliper.
Post up the alignment spec sheet if you can
Buddy you may be right, my guy found the collapsed brake line and showed me my front rotor! HA! I wish I had a picture, matter of fact I will look for it and post soon..... You know the cooling fins sandwiched between the 2 discs that make up your one rotor? the outer side was gone.... I was stoping on the actual fins. it seemed rough for a while then one day it was smooth braking and I figured it was a rock stuck or something . and I thought this new mechanic was trying to tack on some bull $$$ by telling me ohh you had a collapsed line on your front right side caliper .He was dead on! I would have both lines checked before buying a caliper like I did
b.lee likes this.
FORT LEE, NJ 06 2500 Mega Auto. 5.9 245K now 265K in 2 years. stock with no turbo ring ! cts...
ltrcummins is offline
post #24 of 24 (permalink) Old 05-30-2019, 09:19 AM
beren's Avatar
heh. I had a real bad pull when one tire had 4/32s and the other was replaced and with a Dura Grappler and had 16/32s… made a huge difference.
2001.5 HO, 4.10 gear, NV5600, SB Clutch, 4" SS Magnaflow Exhaust, 4th gen Steering, SpynTec hubs, Amsoil Bypass & fluids, Quadzilla iQuad, DAP +75 7x0.0085, BlueChip Diesel VP44 [[email protected] mi], Rust.
beren is offline
Similar Threads
new tires.......now alignment is off and truck pulls to the right. DOC3500 4th Gen Non-Powertrain 15 11-29-2015 06:33 PM
Alignment still out after alignment sundog_ 2010-2012 General Discussion 30 05-17-2015 05:29 PM
Truck Pulls to the Left packing_mules 89-93 Powertrain 4 01-12-2014 07:41 PM
Truck pulls left tannercook7 3rd Gen. Non-Powertrain 15 09-20-2013 11:02 PM
pulls left hi-boost 3rd Gen. Non-Powertrain 11 01-17-2011 03:00 PM
