Dash Removal/Heat/A/C Door Replacement - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 05-16-2019, 11:23 PM Thread Starter
Susie's Avatar
Does anyone have a simple, straight forward way to remove the dash (2003 3500 Dually). I know it is a daunting job, but.... must be done. I have to replace the doors, because as it is I get almost zero Heat, A/C through the vents.
Thanks in Advance.
Don't be so open minded that your brains fall out. :
Susie is offline
post #2 of 12 (permalink) Old 05-17-2019, 12:26 AM
Dylanss180's Avatar
I have done it. Did the blend door usa swap. My HVAC actually works now. If you go on youtube there is a guy there who did a good job showing what needs to be done to do the work.
2003 Ram, 37” tires,Thuren suspension, truss , Radius arms, lockers:Front-Rear-hub, RCV Axles, Ladder Bar, Fusion bumpers, pacbrake E.B., FSO8406A tranny, SAE2 DDC, PSC Hydro Assist steering, Synergy Steering linkages, Carli ball joints, 4.10 gears, 6.7 Ful BLT, twins
Dylanss180 is offline
post #3 of 12 (permalink) Old 05-19-2019, 09:11 AM
BR3500's Avatar
This may help although it's specific to a later MY. Also, IIRC, the newbies guide includes FSM's.
https://www.blenddoorusa.com/pages/i...n-instructions
2006 Dodge Ram 3500 QC/DRW Sport
Mods...what mods? I have to pay for it first
BR3500 is offline
post #4 of 12 (permalink) Old 05-20-2019, 10:53 PM
68Timber's Avatar
How long does this repair typically take to do? I think mine may have this issue.
John
2007 2wd 2500 Laramie crew cab 5.9/auto
68Timber is offline
post #5 of 12 (permalink) Old 05-21-2019, 05:38 PM
IH8CALI's Avatar
Keep us posted on how it goes. My local guy quoted me $700 and he'll do the heater core with a same day turnaround. He can have it for that, i'm always tempted to do it myself though.
06' 2500 QCSB Auto. Thuren 3" w/ 35's 4.56's. Lots of fuel, air & software
(Sold) 04.5 3500 SRW HO 6spd, Thuren Carli Hybrid. I want her back! 3D7LU38C24G196788
(Sold) 02, 99, 93
IH8CALI is online now
post #6 of 12 (permalink) Old 05-22-2019, 10:18 AM
BR3500's Avatar
That's cheap...the Blend Door USA kit is $320. A heater core is around $100 and change. $280 for dash R&R, vent box rebuild labor, AC refrigerant pump down, reclaim, recharge system, shop supplies and overhead....doesn't leave much for profit. Actuator replacements might be a good idea and duct/opening gasket replacements may be needed. More dollars....
BR3500 is offline
post #7 of 12 (permalink) Old 05-22-2019, 02:47 PM
IH8CALI's Avatar
I'm sure the quote didn't account for the cost of the doors, nevertheless it's tempting. As mentioned in the YouTube video though, if you need new foam/weatherstripping as shop probably won't take the time to replace. Same goes with the condenser anti-rub guard that goes around it. There's no sure way of knowing it was done right unless you do it yourself.
(Sold) 02, 99, 93
post #8 of 12 (permalink) Old 05-23-2019, 06:47 AM
BR3500's Avatar
Your last sentence is so true. Trustworthiness seems to be a thing of the past at times....that's unfortunate.
BR3500 is offline
post #9 of 12 (permalink) Old 05-23-2019, 06:10 PM
BR3500's Avatar
Well, tonight's ride home just advanced my addition to the list of Blend Door customers. My AC is more like a heater.....the compressor kicks on and off when the "snowflake" button is operated. No cold air, none, zero. Last season my doors were acting up and this year AC performance was grim. Now it's really grim.....
BR3500 is offline
post #10 of 12 (permalink) Old 05-23-2019, 10:57 PM
It will be winter soon....
davo727 is offline
post #11 of 12 (permalink) Old 05-24-2019, 12:53 AM
Flopster843's Avatar
I can do a full rebuild in about 4 hours by myself, including the evac, disassembly, rebuild with new parts, and recharge. (BTW, I'm the guy from the video)
A few extra things to consider:
  • Replace the heater core and evaporator while you're in the box already. It would suck to have it go out and have to do the entire process again. The best quality I have found so far is stuff from GPD (Global Parts Distributors). I acquire it from Amazon. I've used several of the chain store brands (4 Seasons, Murray, Spectra, etc.) They're literally the exact same part and are of inferior quality than OEM or GPD.
  • Actuators, only utilize OEM actuators from Dodge. All aftermarket actuators that I have came across are inferior to the OEM parts.
  • Get foam to seal the outside of the box. I tried weatherstripping in the videos and it whistled while driving. I later pulled the dash again to replace it with Foam.
  • Make sure you recharge the system by weight, not by pressure. Don't use the disposable cans from the parts store, it's impossible to get an accurate charge that way. Find somebody with a good refrigerant machine (I use a Robinair 34788NI) that can properly evac and charge everything.
  • While the HVAC system is apart, it's not a bad idea to put a new accumulator/dryer on the system. You will sour the old one with moisture when you have it apart.
If you have any questions, I'd be happy to answer them.
John
08 6.7 QC SB 4x4 "hand-shaker" edition, SMARTY powered
Details and Instructions at
Flopster843 is offline
post #12 of 12 (permalink) Old 05-24-2019, 12:25 PM
BR3500's Avatar
That is very true too.....But knowing how my luck seems to go, come winter time, the AC would work great and the heat side would take a nose dive....
BR3500 is offline
Similar Threads
Dash removal really? scippy 98.5-02 Non-Powertrain 12 04-18-2018 09:47 PM
HVAC and dash fixed kleinhhl 3rd Gen. Non-Powertrain 1 07-04-2017 08:49 PM
dash wiring nightmare towtrkah 94-98 Non-Powertrain 2 04-27-2017 11:49 PM
Complete Dash replacement - keyless entry, lower dash, etc. 770guy 94-98 Non-Powertrain 11 02-23-2017 10:46 PM
Vac line to the dash buguy 94-98 Powertrain 5 09-21-2012 08:41 AM
