Need recommendations, found some issues under the truck. - Dodge Cummins Diesel Forum
 2Likes
post #1 of 18 (permalink) Old 04-24-2019, 04:25 PM Thread Starter
Justintoxicated's Avatar
I was installing my nerf bars and found some issues under my truck.
Cracked exhaust after the muffler. Best fix?
Oil Pan leak. Take this to a shop to fix or just keep checking oil levels? It's not leaking on the driveway or anything.
Transmission leak? Also not leaking on the driveway.
Power steering leak (power steering is a bit low) Not sure where it's leaking from.
Also, ordered some new sway bar end links.
ID:	846379   Click image for larger version
ID:	846381   Click image for larger version
ID:	846383   Click image for larger version
ID:	846385   Click image for larger version
Justintoxicated is offline
post #2 of 18 (permalink) Old 04-24-2019, 04:29 PM
MAR524AK's Avatar
How many miles on truck? Could be rear main seal leak. Exhaust you could try and tack weld it up or get a new pipe installed.
Sent from my iPhone using Tapatalk Pro
MAR524AK is offline
The Following User Says Thank You to MAR524AK For This Useful Post:
Justintoxicated (04-24-2019)
post #3 of 18 (permalink) Old 04-24-2019, 04:32 PM Thread Starter
I'll have to look when I get home, It was my Dad's truck before. I think mileage is around 140k. I don't weld, so I guess the easy fix would be to take it to an exhaust shop to repair? Or would I be better off buying a new exhaust and trying to install it myself? I'm ok with working on things myself as long as I don't need a lift etc and don't take too long to complete.
post #4 of 18 (permalink) Old 04-24-2019, 04:33 PM
MAR524AK's Avatar
Yea you can take to exhaust shop to repair or just straight pipe it! Buy a kit and install yourself. Pretty easy deal
MAR524AK is offline
post #5 of 18 (permalink) Old 04-24-2019, 04:37 PM Thread Starter
Thanks, I'm in California if that matters, I know there are allot of exhaust restrictions on cars but not sure if that applies to an 05 diesel.
Maybe something like this?
https://store.mbrpautomotive.com/en/...exit-t304.html
post #6 of 18 (permalink) Old 04-24-2019, 04:42 PM
MAR524AK's Avatar
North or south California? Just be smart about it. There are tons of moded trucks in California.
MAR524AK is offline
post #7 of 18 (permalink) Old 04-24-2019, 04:53 PM Thread Starter
San Diego, updated my profile.
MAR524AK likes this.
post #8 of 18 (permalink) Old 04-24-2019, 05:22 PM
4everlearning's Avatar
Get an exhaust that keeps a cat.
2005 QCSB, cold air intake, guages, a trans built by me and HPTuners tunes by me
4everlearning is online now
post #9 of 18 (permalink) Old 04-24-2019, 05:26 PM Thread Starter
Any suggestions? It's not my daily driver but it is our tow vehicle. Of course we use it for other truck stuff too. I may be the only tesla model 3 owner that also owns an old diesel truck hah (Don't hate!)
post #10 of 18 (permalink) Old 04-24-2019, 08:40 PM
You arenít the only one to own a Tesla and an older dodge diesel. Thereís plenty of people around here where I live that match that.
I honestly donít think thereís that much difference in the name brand exhaust systems.
I say to stick with a cat so that you can continue to pass emissions down where you are. Iím lucky and donít have to pass emissions even tho I live in California.
post #11 of 18 (permalink) Old 04-24-2019, 09:35 PM Thread Starter
I'm not sure what is required to pass emissions here, I know there is some free smogcheck thing but I don't think it's very strict. Should I look into a catback then? Probably cheaper too? Truck also needs shocks and a bedliner to get it where I want it, I'm I'm sure bushing are somewhere on the list too.
What about all those leaking oil pans and power steering?
post #12 of 18 (permalink) Old 04-24-2019, 10:15 PM
MDSWA's Avatar
Here's how I would approach it:
Have muffler shop replace tailpipe or buy an aftermarket one and install yourself
Start by "gently" re-torquing pan bolts. Clean pan with a de-greaser and check to see if you got it. Pulling oil pan and changing the gasket is a big deal. Have to partially lift the motor for clearance. Also, oil runs downhill so leaks that are higher up on the engine may cause oil to accumulate on the pan.
Transmission leak? Also not leaking on the driveway. Is it time for a transmission flush? Service the tranny and replace the gasket at the same time.
Power steering leak (power steering is a bit low) Not sure where it's leaking from. De-grease the pump and surrounding area drive it a couple days to isolate where the leak is.
4everlearning likes this.
MDSWA is offline
The Following User Says Thank You to MDSWA For This Useful Post:
Similar Threads
DEF issues Poll CGCampbell07 2013+ General Discussion 430 06-11-2018 09:46 PM
2013 & Up Issues Thread 6401nohl 2013+ General Discussion 1198 04-01-2017 07:33 AM
Issues While driving/accelerating. Bisonian 3rd Gen. Powertrain 7 03-07-2016 06:37 PM
Shift Issues, Vibration @60mph, AC Blows Hot & Washer Fluid Light on...Pandoras Keeps cpao1064 3rd Gen. Powertrain 4 07-26-2013 04:01 PM
Fuel Requirements For Cummins Engines - Service Bulletin 3379001 LReiff Technical Service Bulletins & Recall Support 9 11-17-2012 02:48 PM
