DRW to SRW Swap - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 04-18-2019, 09:44 PM Thread Starter
DRW to SRW Swap
So I just purchased some 18 inch wheels from a 2016 Laramie and I’m wanting to use them to convert my dually to a srw. But when I was headed to put the rears on the floating hub is significantly bigger than the inner hole of the wheels I purchased. My question is can I remove that part of my dually axle or am I screwed and need to replace the axle all together?
MK USCG
2003 ccsb Laramie 2500-sold
2011 ccsb Laramie 2500
loggs1369 is offline
post #2 of 9 (permalink) Old 04-22-2019, 09:53 AM
CTD NUT's Avatar
The rear DRW axle is wider than the SRW axle so even if wheels did bolt on you would be faced with that issue as well. That said, SRW bearing hubs and DRW bearing hubs are the same OD so something isn't right with those wheels.
03 3500 QC DRW 4x4 6spd-6.7 Swap w/DPS S475/ported HE351 Twins, Smarty MM3/Calibrated Power tuning, F1 60 HP sticks, Pacbrake PRXB w/5" Flo Pro exhaust
CTD NUT is offline
post #3 of 9 (permalink) Old 04-22-2019, 10:49 AM Thread Starter
So attached are the wheels I purchased. They are from a 2016 2500. But when I went to mount them the center won’t go over the hub that sticks out from the caliper. I get that the axle is wider but I bought 1.5” spacers for the front wheels so that the track would be the same. The part that is circle in the second picture is from a 2500 but on my dually 3500 it’s about twice that long. So there’s no way for those wheels to fit on there but I don’t even know if it would fit on that 2500 axle either. Did the axles change diameter on the hub for newer vehicles?
MK USCG
post #4 of 9 (permalink) Old 04-22-2019, 02:14 PM
CTD NUT's Avatar
There is no bearing hub OD difference between 3rd and 4th gen trucks that I am aware of. That said, I'm not that familiar with late 4th gen stuff. Everything I have seen is that they are all 4.75" OD hubs that accept a 4.78" ID wheel.
The DRW bearing hub is longer on all of the DRW axles compared to the SRW axles. But that should only stop the SRW center cap from fitting. The wheel should still fit over the hub. What is the ID of the wheel?
CTD NUT is offline
post #5 of 9 (permalink) Old 04-22-2019, 02:45 PM Thread Starter
The center cap is probably 3.5 inches across. But it isn’t removable on these wheels so I think the short hub bearing would work but with the long one on the dually it isn’t going to work. I think I’ll just sell these wheels and replace the dually tires for now.
MK USCG
post #6 of 9 (permalink) Old 04-22-2019, 03:54 PM
Gator1's Avatar
Ya my 1 ton axle flange is 4.7" You need 1 ton wheels to do that, not 3/4 ton, or what they call "super singles" The "gen' has nothing to do with it. You have a 1 ton floating axle on a 1 ton, totally diff animal than a 3/4 ton.
03 Dodge SHO QCLB Dually w/ Banks intercooler 4" side draft intake. Carli/Thuren Argon filled Shocks, radius arms, SRW 4 link Conversion, 17"methods, 42" Squishy's, / 25.263 mpg legit. Disabled Marine wartime veteran.
Gator1 is online now
post #7 of 9 (permalink) Old 04-22-2019, 05:09 PM Thread Starter
Yep so I just posted them for sale. Hopefully I can get what I paid for them. Gonna keep it a dually and probably just trade it in for a newer 2500.
MK USCG
post #8 of 9 (permalink) Old 04-22-2019, 05:33 PM
Electrojake's Avatar
Post me a link friend.
2016 Longhorn 3500 4x4 short-bed in Pearl White.
Cummins-AISIN, CrewCab, SRW, Ride-Rite remote rear air suspension, Edge CTS2, plus the typical after-market bolt-on crap.
*Hauling a 2017 Northstar Arrow-U.
Electrojake is online now
post #9 of 9 (permalink) Old 04-23-2019, 07:54 PM Thread Starter
https://offerup.co/0sv5J5Tl8V If you don’t have offer up I can send you pics.
MK USCG
Similar Threads
Another successful 48RE to G56 6 speed swap MTMike 3rd Gen. Powertrain 72 05-08-2018 03:19 PM
Mechanical Speedometer Swap JState 89-93 Non-Powertrain 5 01-03-2015 07:37 PM
NV4500 Swap Tutorial With Pictures Diesel_Addiction 94-98 Powertrain 24 12-01-2013 03:15 PM
Manual to Auto Swap questions luckyhat12 3rd Gen. Powertrain 12 09-11-2012 07:01 PM
d80 limited slip carrier swap possible? brianell 98.5-02 Powertrain 3 08-08-2012 02:16 PM
