2005 Fog light wiring diagram - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 04-15-2019, 05:33 PM Thread Starter
My 2005 does not have factory fog lights, but it is wired for it.
I was wanting to use the factory wiring to turn on a set of aftermarket lights, does anyone know the wiring diagram?
The bumper plug is 2 prong, black and yellow/white, I assume the yellow/white is fog light positive the black being ground (?)
IF that is a ground does it need to be hooked up or can I only use the positive on my fog lights and just case ground the lights? (I don't know how the 'LAMP OUT" works, if its related)
It looks like being a 2005 I don't need to get anything turned on in the computer at the dealer correct?
I bought a headlight switch with fog lights, the fuse is in, the relay is in, but when I turn the switch on, I don't see 12V+ at the Yellow/white wire.
Pin 30 at the relay does not have power.
Could it be a defective switch?
welndmn is offline
post #2 of 5 (permalink) Old 04-15-2019, 07:27 PM
TECH SPECIALIST
steve05ram360's Avatar
Welcome to cumminsforum...
Search for the newbies guide to the new to you truck & download the service manual, open with adobe. You will find whats needed in there
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 409k, HPTuners, G56, 23.348 mpg, mpg threads ->
steve05ram360 is offline
post #3 of 5 (permalink) Old 04-15-2019, 07:28 PM
TECH SPECIALIST
post #4 of 5 (permalink) Old 04-15-2019, 07:28 PM
TWR
TWR's Avatar
Hi pin 30 and pin 86 should be live all the time from the fuse in PDC.
2003 Ram 3500 6 inch lift, 2012 seats and console [email protected] Shifter, Fass 95 pump, Built 47re and mishimoto trans cooler, Srt10 hood, Smarty touch.
TWR is offline
post #5 of 5 (permalink) Old 04-16-2019, 08:25 AM
TeamDoty's Avatar
Does your headlight knob also pull out a notch when your headlights are turned on?
If so turn lights on, pull out on the knob and use a test light at the end of the harness up there. I think mine terminated around the washer reservoir.
I used the factory harness to flip a relay to power bigger off road lights.
2005 3500 SLT 4x4|4" Ex.|Cooper STT Pro 315/70R17|HellBent 2" Lvl|Synergy Adj Track Bar/Steering System|Thuren Shocks|MOPAR 1pc Driveshaft/Big Steering Box|Carli Ball Joints/Control Arms/Diff' Guard|Banks High-Ram Intake|Maverick Ranch Bumper #12K Winch
TeamDoty is offline
Similar Threads
30" Curved LED Light Bar Installed - Flush In Between Tow Hooks brandonjansen 4th Gen Non-Powertrain 390 06-08-2018 05:52 PM
Wylde Wiring Adventure, or How to Tow your non-Tow Harness WyldeRyde 94-98 Non-Powertrain 10 05-17-2017 09:19 PM
Replaced tail light wiring end and now I have no brake light Truck Guy99 98.5-02 Non-Powertrain 4 04-17-2015 03:23 PM
Light load tire pressure W8n4Snow12 2010-2012 General Discussion 3 04-14-2013 03:46 PM
Cab light bulb size 6intip 07.5 - 09 3rd Gen 6.7L Non-Powertrain 1 06-21-2011 05:43 PM
