2004.5 radiator replacement options/improvements? - Dodge Cummins Diesel Forum
 10Likes
post #1 of 13 (permalink) Old 04-14-2019, 05:08 AM Thread Starter
Recently my plastic tanked radiator started dripping from the bottom corner right by the drain pet. It appears to be coming from where the plastic tank is clamped to the metal core. It is not very bad at all yet but now definitely on the to-do list before summer heat.
Wondering what is the best affordable improvement replacement? Is there a newer year factory unit with improved cooling that will bolt in?
Right now finances dictate shopping used OEM preferred instead of cheap chinese, just looking for the best one to look for.
I vaguely recall discussion of maybe a 2007 being a good upgrade for older rigs but can't find it again, and won't trust my vague memory.
Searched and read some threads that mostly talked about 3 row vs 2 row vs expensive aftermarket but didn't find anything about improvements in OEM from different year gen 3 rigs.
Thanks!
2004.5 2500 4x4 short bed AT, 249,000 mi
assume all stock except K&N filter & intake tube but history prior to 220,000 miles is unknown
DaveH77 is offline
post #2 of 13 (permalink) Old 04-14-2019, 10:08 AM
jerrodlk's Avatar
I installed one from O’Reilly. It works just fine for me.
However I also installed a thermostat from O’Reilly and it was junk. Had to replace the O’Reilly thermostat with one from NAPA and replaced the radiator cap with OEM. Now I’m good on cooling.
'07 - 2500 Quad Cab - 5.9L - 4x4 - Auto - 285/70-17 BFGs - B&W Hitch - 3:73 Limited Slip - Laramie - Steering Box Brace - 08.5 Steering - GDP MK-2 - EGT/Boost Gages - HellWig Big Wig Sway Bar - Stock Tune - 340k miles - Patriot Blue
jerrodlk is offline
post #3 of 13 (permalink) Old 04-14-2019, 12:09 PM
verdesardog's Avatar
I recently put an all aluminum radiator in my 06. Got it from ebay, it looks and performs very nice. the only thing is it take a smaller radiator cap! It looks like a mishomoto knock off.
2006 4X4 IMAGINE ALL THE PEOPLE LIVING LIFE IN PEACE
verdesardog is offline
post #4 of 13 (permalink) Old 04-15-2019, 01:50 PM
TECH SPECIALIST
steve05ram360's Avatar
My OEM radiator had a nasty end tank leak, I took a pair of vice grips to all of the crimps on each tank and tossed it back in there. The intent was to have it last long enough for me to go source a better radiator than what I pulled out (BTR junk) and be off & running again leak free.
2+ years later, still no leaks from it and I have not swapped it out.
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 428k, HPTuners, G56, 25.065 mpg, mpg threads ->https://www.cumminsforum.com/forum/3...l#post23312562
steve05ram360 is offline
post #5 of 13 (permalink) Old 04-15-2019, 03:54 PM
utahtrapper's Avatar
All Aluminum would be the way to go.
I broke the factory plastic drain when I did my flush. LOL POS.
I was lucky and found a Mishimoto someone bought and then sold his truck. I do really like and for 400.00 not to Bad.
2006 Blue Laramie DRW. 3500 5.9 G56 Mobil Delvac 50, Tans Cool PTO Covers, GDP Fuel Boss, GDP Double-X Ladder Bars, GPD big line kit, GDP MK-2 Fuel filter kit with CAT UHE 416 1225, GDP Power-Flo Intake Manifold, Throttle Up Industries Dual Fuel Filters, Dieselsite Coolant Filter, Cool Hose, Timbrens, 26k with Horses in Trailer, ................... BBi's .5 Towing Injectors WOW!
Carli Ball Joints
utahtrapper is offline
post #6 of 13 (permalink) Old 04-16-2019, 10:12 PM
Dave, I think you got your answer in post #4. Steve's always good for an effective economical solution.....
Thank you Steve. I've considered that a couple times over the years and just ended up replacing a radiator. Valuable info like THIS is why forums like this are great!
steve05ram360 and 24hrsparkey like this.
07 5.9 Mega, G56, SB Single disk Ceramic clutch, OE 1 piece Al driveshaft, 60hp Industrial injectors, Triple dog, Glacier 2mic filter, BD exhaust brake, ATI Super Damper, BD steering brace, Firestone bags, Big Wig swaybar, 4th Gen 20s and some home made Stableloads.
Grit dog is offline
post #7 of 13 (permalink) Old 04-16-2019, 11:48 PM
TECH SPECIALIST
Here is the thread where i did the work. 11/2016...
https://www.cumminsforum.com/forum/3...air-print.html
post #8 of 13 (permalink) Old 04-17-2019, 09:49 AM
Yaeh NEVER use that dinkey pet gizmo for that very reason.
Just pull the lower hose ( carefully) and let nature take its course.
utahtrapper likes this.
SOLD My 2001 and 2005 .
SOLD 2004.5 Sons mod truck
24hrsparkey is online now
post #9 of 13 (permalink) Old 04-22-2019, 12:15 PM Thread Starter
Hello Steve and everyone,
I was actually wondering if I could clamp it again. Its not much of a leak, about 6" of damp concrete overnight, but can't tell when driving under full pressure. Didn't want to go crimping on the 14 yr old plastic POS unless someone had gone there before. Definitely didn't want to risk making it worse and have absolute replacement come even sooner.
I have built and worked on a lot of classic muscle cars in the distant past, always a challenge to keep those old gassers cool, especially in summer heat & in town traffic.
4 core brass was always the ticket, over 400 cid and 400+HP a 4 core would barely do it but it was the best we had. HD thermo clutch fan out of a 500cid Cadillac helped a lot.
Thanks guys, Dave
DaveH77 is offline
post #10 of 13 (permalink) Old 04-22-2019, 01:09 PM
Gator1's Avatar
Yes, it's called a lifetime guaranteed aluminum radiator from Mishimoto and Kool thermostat.
steve05ram360 and utahtrapper like this.
03 QCLB- 19 to 25 mpg with electric parts, and engine mods....
Gator1 is offline
post #11 of 13 (permalink) Old 04-22-2019, 04:53 PM
TECH SPECIALIST
Thanks guys, Dave
I clamped on mine 1x with zero issues in the time after... you can certainly try it... just set the vice grip so it does not over crimp it. Read up/look up web info on it or videos...
post #12 of 13 (permalink) Old 04-22-2019, 04:54 PM
TECH SPECIALIST
that would require a new shroud for my fans if the core size is different... would be a good excuse to go to rev b of the shroud.
Similar Threads
2004.5 48re to g56 swap - with pictures! KCT 3rd Gen. Powertrain 63 08-06-2016 12:09 PM
Considering buying 2004.5 Ram, any specific concerns? Dudeonthenet 3rd Gen. Powertrain 18 03-07-2014 08:59 PM
2004.5 Dually With Blown Engine..... Skag 3rd Gen. Powertrain 15 01-23-2013 07:07 AM
2004.5 Dodge Diesel 3500; Need some good advice about my 2004.5 Dodge Diesel traver 3rd Gen. Powertrain 6 07-03-2012 03:07 PM
2005 Engine swap into 2004.5 truck, no accelerator response? dirtydodge38 3rd Gen. Non-Powertrain 4 07-31-2011 05:18 AM
