2005 Blinker intermittent and not working - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By deeselnewbie
post #1 of 6 (permalink) Old 04-13-2019, 08:02 PM Thread Starter
deeselnewbie's Avatar
My turn signals are acting up. I hit the left and the right turns on. I turn the right and nothing blinks. I am currently working on the fuse box to find a solution by switching fuses around same Amps. Also when I turn on emergency flashers they work Sporadically as I touch the turn signal.
I am sure it’s the multi turn signal switch on the column. Is that an easy project or more have a shop do it? I really would rather not mess with air bags.
2005 Dodge 3500 automatic
deeselnewbie is offline
post #2 of 6 (permalink) Old 04-13-2019, 09:19 PM Thread Starter
Ok look like the part off amazon is only $66 bucks and five minutes to install. Will order. No need to take off steering wheel.
post #3 of 6 (permalink) Old 04-13-2019, 09:25 PM
TECH SPECIALIST
steve05ram360's Avatar
Yeah it is a quick swap, napa has them for $75 as well...
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 415k, HPTuners, G56, 25.065 mpg, mpg threads ->
steve05ram360 is offline
post #4 of 6 (permalink) Old 04-14-2019, 05:07 AM
360 ci's Avatar
i changed mine on my 06 super simple found a video on you tube took like 10 min.
360 ci is offline
post #5 of 6 (permalink) Old 04-14-2019, 09:39 PM Thread Starter
You know what’s even cooler?
After I had it out, I disassembled it. Cleaned it with electrical spray and re dielectric greased it and plugged it back in and it works fine now. Easy process just three torex screws and cleaned the gunk off and it’s like new.
steve05ram360 likes this.
post #6 of 6 (permalink) Old 04-15-2019, 02:00 PM
I cleaned mine as well when it wasn't working. Covered in dielectric grease and is still working good a year later
2005 ccsb. 48re. mbrp 4". leveled on 35's.
Albertan is offline
