trailer wiring/ brake controller - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 04-11-2019, 08:59 PM Thread Starter
wanna12vc's Avatar
So my 2003 cclb had a 4 wire to a 7 wire plug set up when I bought the truck.
The 4 wires go into what look like a factory harness but I cant be sure.
There is the factory plug under the dash that when I plug a brake controller into it gets power but obviously doesn't connect to the trailer.
So what I need to do it make the 7 pin plug work with the brake controller.
What can I look at to see what I need to make this work.
Is there a new harness that I need? If so where can I get it?
Thanks
1993 w250 club cab getrag 5 speed 3.55 gears, 2.5" front alcans,305x70r16 BFG A/T, BD fuel pin from thehungrydiesel, HX35, 4" diamond eye straight pipe, hurst shifter, factory tach, egt and boost gauges, round about 350,000 miles
wanna12vc is offline
post #2 of 3 (permalink) Old 04-12-2019, 01:35 AM
evildiesel's Avatar
Once you plug a brake controller to that connector under the dash, connect your trailer to the 7 pin and go. It’s all pre-wired and ready to go.
2006 Dodge Ram 2500 ST, RCLB, G56
AFE Intake - 4" Straight Flo-Pro Exhaust - EFILIVE - CARLI - TGC 3.5" lift - 20x12 wheels - 35" AT2 Tires
evildiesel is offline
post #3 of 3 (permalink) Old 04-14-2019, 02:43 AM
tryNto's Avatar
^^ agree with what he said
'03 QCLB 2500 305/555 NV5600 w/ FastCoolers 3.73 4x4, Color match Lear Topper.
Smarty S-06 PoD, Edge CTS for Gauges, DPP Cool Tube w/ OEM AF Box, Baldwin PF7977, GDP MK-2 FF Kit, Pusher Intake Horn, Adj. Boost Elbow @ 30psi, OEM Fan Clutch Delete/Mod, Steering Box Brace, On-Board Air w/Horns
tryNto is offline
Similar Threads
Factory Trailer Brake Problems Truno223 4th Gen Non-Powertrain 5 08-05-2017 07:42 PM
2013 and up Mileage Thread 5001craig 2013+ General Discussion 1857 04-15-2017 01:20 AM
2011 OEM Trailer brake controller disconnected NRU Hobo 4th Gen Non-Powertrain 5 06-25-2013 07:33 AM
New trailer brake controller in an 05 doesnt work the brakes vilaubi57 3rd Gen. Non-Powertrain 4 12-01-2012 04:11 PM
ABS and brake warning lights, trailer brake controller won't activate gator_grabber 94-98 Non-Powertrain 12 12-30-2010 07:17 PM
