RedHead steering box done - Page 2 - Dodge Cummins Diesel Forum
 14Likes
post #13 of 15 (permalink) Old 04-12-2019, 09:26 AM Thread Starter
TECH SPECIALIST
steve05ram360's Avatar
here you go....
Loki223 and Babin Farms like this.
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 403k, HPTuners, G56, 23.348 mpg, mpg threads ->
steve05ram360 is offline
post #14 of 15 (permalink) Old 04-12-2019, 11:55 AM
Diesel Freakazoid
Loki223's Avatar
It was a good seat, at least i know where one part of my old truck is, and i know it's getting the love it deserves! lol
steve05ram360 likes this.
2012 MCSB DRW 3500 Laramie Longhorn, EFI Live By ANARCHY Diesel, 4" flopro turbo back with muffler, S&B air box and filter, Edge Insight CTS2, 2" HBS level, Bilstein 5100s in all 4 corners with steering stabilizer, PacBrake Airbags, GDP Fuel Filter under the hood, Supernova V3 LED headlights and my EGR stuff ran away, lemme know if you find it
HELP ME UPDATE MY IMAGES, IF YOU SEE A BROKEN IMAGE LINK, SEND ME A PRIVATE MESSAGE SO I CAN UPDATE THE IMAGE TO A NEW HOSTING SITE
Loki223 is offline
post #15 of 15 (permalink) Old 04-16-2019, 12:10 PM Thread Starter
TECH SPECIALIST
I returned the core to red head and asked for a RCA (root cause analysis) on the failure, leak... they called back today and mentioned a metal washer had worn in one spot caused by sector shaft wiggle. That wear allowed fluid past it and ultimately past the seal when it was cold (the only time it leaked). Otherwise that box was still good to go.
The wear came from the bolts holding the sector shaft bearing to the brace coming loose and allowing the shaft to wiggle under load. I have since fixed that issue by using beefier bolts with lock washers. Which reminds me, there is only 1 way to install that bearing as its an offset bearing. Going to crawl under there and make sure it is positioned correctly since I did not do the install.
Hope this helps someone down the road...
Similar Threads
Redhead box + steering shaft Lumpy973 3rd Gen. Non-Powertrain 7 04-08-2019 10:34 AM
Steering kit advice Cat-man 3rd Gen. Non-Powertrain 67 10-25-2018 07:48 PM
Redhead steering box... gmbohuntr 07.5 - 09 3rd Gen 6.7 Liter General Discussion 4 04-21-2018 06:31 PM
Psc sg-850 steering gearbox wyldbill100 94-98 Non-Powertrain 4 02-28-2018 10:21 PM
