Transfer case rear output shaft seal - Page 2 - Dodge Cummins Diesel Forum
 2Likes
post #13 of 24 (permalink) Old 04-08-2019, 04:00 PM Thread Starter
Thanks for all the input, gentlemen. I checked my service bill and the part number for the seal is skf 23000. Unfortunately I don't know how to upload the photo. (looks somewhat like a ball joint cover) Will do some homework on all the suggestions. Again, thanks to all....will keep you posted....Keith
ABMegacab is offline
post #14 of 24 (permalink) Old 04-08-2019, 04:27 PM
4everlearning's Avatar
That is a double seal
2005 QCSB, cold air intake, guages, a trans built by me and HPTuners tunes by me
4everlearning is offline
The Following User Says Thank You to 4everlearning For This Useful Post:
ABMegacab (04-08-2019)
post #15 of 24 (permalink) Old 04-08-2019, 05:29 PM Thread Starter
Originally Posted by CTD NUT View Post
If you can't get the tail stock bushing serviced easily, you can buy a complete new replacement tail housing assembly. Just bolt it on and go. https://torqueking.com/product/11013...nv271d-nv273d/
Is this part available from a Canadian source? Thanks for the info on the seal.
post #16 of 24 (permalink) Old 04-09-2019, 06:29 AM
rghavana's Avatar
Hate to tell you but, If you have 2 piece drive shaft only cure for alot of similiar issues you are expieriening is to replace with 1 piece drive shaft, alot of problems with 2 piece shafts in these trucks.
Best is Driveshaft Specialist Inc
04 QCSB HO Automatic
rghavana is offline
post #17 of 24 (permalink) Old 04-09-2019, 07:35 AM
Babin Farms's Avatar
I thought that my rear output seal was leaking and replaced it twice and it still leaked. After cleaning it up multiple times to try to figure out where the oil was coming from it turned out the yoke was leaking where the plug in the end is pressed in. I tried silicone, epoxy and other stuff but had to weld the plug in to get it to stop leaking. Might want to check into it
2017 GMC 2500 6.0
SOLD - 2008 3500SRWCCLB 4x4 6.7 Cummins, G56 w/South Bend DD
Babin Farms is offline
post #18 of 24 (permalink) Old 04-09-2019, 08:21 AM
CTD NUT's Avatar
I'm not sure. At the local level, a good transmission shop would probably be able to source it for you. But that same shop would also be able replace just the bushing for you as well.
03 3500 QC DRW 4x4 6spd-6.7 Swap w/DPS S475/ported HE351 Twins, Smarty MM3/Calibrated Power tuning, F1 60 HP sticks, Pacbrake PRXB w/5" Flo Pro exhaust
CTD NUT is offline
post #19 of 24 (permalink) Old 04-09-2019, 08:23 AM
CTD NUT's Avatar
This is a very good point and one that I forgot about.
However, if the OP replaces the seal and the leaks stops for a period of time, it isn't that leaky plug.
CTD NUT is offline
post #20 of 24 (permalink) Old 04-09-2019, 11:53 AM Thread Starter
I appreciate all the input gentlemen. My biggest disadvantage is having to drive long distances to access someone to work on it, the joys of small town living. I will look into each of your suggestions. I'm wondering if the seal is lasting a year and a half, is that normal wear and tear or indicative of another problem as pointed out by you all? Thanks again. At this point, I am inclined to replace the seal and move on but wonder whether hidden damage is being done by missing something.
post #21 of 24 (permalink) Old 04-09-2019, 04:00 PM
CTD NUT's Avatar
That is not normal wear and tear for that seal. That seal is failing prematurely because there is too much run out on the slip yoke because it is not being stabilized well enough because the bushing is worn too much. The seal has some give and can deal with a little run out but over time, it will fail as a result.
There isn't really any other damage being done other than ATF undercoating your truck when the leak starts.
CTD NUT is offline
post #22 of 24 (permalink) Old 04-09-2019, 06:49 PM Thread Starter
Appeciate that....actually there is little fluid on the undercarriage, just drips onto the garage floor after a long trip. Will look at replacing the bushing or tail piece in the future.
post #23 of 24 (permalink) Old 04-12-2019, 05:14 PM Thread Starter
Quick update, bought the tail section from Torque King on Amazon.ca. The price was cheaper but with shipping, still worked out to $250 CAD. For any of you American friends, Walmart sells this item for $119 USD, but still sources it to Torque King. Contacted my mechanic who will have no problem r&ring this. So I will have an extra on hand should I need one in the future, or sell to anyone. Again thanks for all your input and wisdom.
CTD NUT and 4everlearning like this.
post #24 of 24 (permalink) Old 04-12-2019, 08:37 PM
Glad you’re going to get it fixed up right.
Similar Threads
Rear drive shaft stuck in transfer case Tdubliture 94-98 Powertrain 16 08-14-2016 09:27 PM
2001 2500: Another bad automatic transmission defdes 911 Urgent Situations 5 01-31-2015 07:41 PM
Another Transmission issue ThatOneGuy469 3rd Gen. Powertrain 15 08-03-2012 04:54 PM
Rear transfer case seal lpnlizard 2003/2004 General Discussion 2 05-13-2012 01:38 AM
48re Question Driller05 3rd Gen. Powertrain 8 09-10-2011 06:29 AM
