Best oil filter? - Page 2 - Dodge Cummins Diesel Forum
 4Likes
post #13 of 30 (permalink) Old 04-04-2019, 01:11 PM
GRUNT 11B's Avatar
I use the donaldson dbl7349. I did some research on oil filters and decided that Donaldson would be a solid choice to go with.
06 QCLB 4X4 G56, SOUTHBEND DD, FASS 150, ARP STUDS, 50HP INJECTORS, EFI, HE351 S475 COMPOUNDS, FLUIDAMPR, HAMILTON PUSHRODS & 103# SPRINGS, 624 HP 1090 TQ 01 QCLB 4X4 AUTO, WHEELS, TIRES, STEERING WHEEL, CUMMINS, BUMPERS, FUEL TANK, SEATS, ETC.
GRUNT 11B is offline
post #14 of 30 (permalink) Old 04-04-2019, 09:12 PM
evildiesel's Avatar
Fleetguard stratapore 16035 gets my vote
2006 Dodge Ram 2500 ST, RCLB, G56
AFE Intake - 4" Straight Flo-Pro Exhaust - EFILIVE - Southbend DD Clutch - CARLI - TGC 3.5" lift - 20x12 wheels - 35" AT2 Tires
evildiesel is offline
post #15 of 30 (permalink) Old 04-04-2019, 10:11 PM Thread Starter
Millionmiles's Avatar
Originally Posted by on the ridge View Post
Originally Posted by BR3500 View Post
I've been using the LF16035. I'm wondering how is the LF9028 working out?
The LF9028 has a built in bypass filter on one end of the filter. The filter is dimensionally about the same externally. The filter externally appears similar to other filters with the exception that there are no flutes or flats on the end. This means that to remove the filter you need to use a band style wrench. I purchased a band style wrench that has no built in handle on it, but instead accepts a 3/8" socket wrench or 3/8" extension.This filter is able to filter out smaller particles, such as carbon, because of the bypass portion. Because of the in-cylinder EGR inherent in our generation Cummins engine more carbon is released to the engine oil. The filter does cost more, currently $33.29 on Amazon. But you do not have the extra plumbing and filter of an added bypass filter system. I change my oil annually, I thought the added cost was acceptable.
This sounds awesome. I have been looking at the Donaldson Blues. They have a 10 micron rating that’s nice. Also considering a true bypass filter. I drive around 20k a year over a cascade mountain pass and changing my oil every 3 months is extreme. So I’m switching to amsoil 15-40 soon and want a filter system that last 10-15k.
2018 CCSB Manual
Millionmiles is offline
post #16 of 30 (permalink) Old 04-04-2019, 10:21 PM
COFFMAN CUSTOMS
AH64ID's Avatar
Donaldson DBL7349... the spec's don't lie, nothing else comes close to it.
GRUNT 11B likes this.
2018 Ram 3500 Laramie CC LB
6.7, Aisin, Auto-Level
AH64ID is offline
The Following User Says Thank You to AH64ID For This Useful Post:
Broaner (04-05-2019)
post #17 of 30 (permalink) Old 04-05-2019, 10:37 AM Thread Starter
Stepping it up to an Amsoil dual bypass system next. After reading about it on the Amsoil site it’s the only way to go for me. I know there is a lot on here about it starving your engine of oil but that’s just not true and silly. If you get on their site and read about it you will understand how it works. From what I understand the main full flow filter is rated at 20 microns. A small amount constantly goes through the 2 micron bypass filter. I don’t like the install requirements for their single bypass and with the dual you get both filters up where you can easily service them.
2018 CCSB Manual
post #18 of 30 (permalink) Old 04-08-2019, 09:45 PM
Grogg's Avatar
DBL7349 painted black with Scamsoilz sticker on it
brooklyn 12 likes this.
2006 RAM 3500 DRW 6 speed 4WD QCLB: unit bearing delete, metric delete, all tow no go.
1991 W350 SRW auto 4WD RCLB: Fleetjunk delete, Garmon trans, NASTRUCK
Just say no to metric Daimler-Fiat
Grogg is offline
post #19 of 30 (permalink) Old 04-08-2019, 10:14 PM
COFFMAN CUSTOMS
AH64ID's Avatar
The DBL7349 and EaO80 are the same filter with different labels.
I have dual remotes and single remotes. The single remote and a DBL7349 is the cheapest change, and the media is the same.
I have yet to find a good location for a dual remote on a Dodge/Ram, but plenty of good choices for a single remote bypass. The install requirements are no different for single or dual, only the space requirements.
rghavana likes this.
AH64ID is offline
post #20 of 30 (permalink) Old 04-08-2019, 11:34 PM Thread Starter
Install is different.
ID:	845179   Click image for larger version
2018 CCSB Manual
post #21 of 30 (permalink) Old 04-08-2019, 11:35 PM Thread Starter
https://www.amsoil.com/bypass/how-it-works.aspx
Illustrations are hard to see. Here is the link
2018 CCSB Manual
post #22 of 30 (permalink) Old 04-11-2019, 03:52 PM
I plan to use the Baldwin BD7317, which has the dual flow vortex (5 micron I think) bypass inside., same as the other.
http://www.baldwinfilter.com/literat...ts/form331.pdf
So you get a bypass and standard filtration just by buying one filter. No need to do the extra work and expense of installing a separate bypass filter. I found ZORO has the best online price for them, got to buy $50 worth to get free shipping.
sdowney717 is offline
post #23 of 30 (permalink) Old 04-21-2019, 10:15 AM
donaldson dbl7349
03 qcsb black 4x4 Calibrated Power thuren bd r850 48re 10.2 stroker pump, bbi stage 2s studs springs pushrods fully ported head banks side draft bd ex manifold intercooler fuel boss 2mic ham cam 188/220 flexalite
1985cucv is offline
post #24 of 30 (permalink) Old 04-21-2019, 10:46 AM
TECH SPECIALIST
steve05ram360's Avatar
Centrifuge.... And no i dont use it...
https://www.iowa80.com/pd/spinner-ii...yABEgIER_D_BwE
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 415k, HPTuners, G56, 25.065 mpg, mpg threads ->
steve05ram360 is offline
Similar Threads
Spin-on Power Steering Filter dauntless89 94-98 Non-Powertrain 69 09-14-2018 05:09 PM
d89 Presents: How to Install a BHAF Without Completely Screwing it Up dauntless89 94-98 Performance Parts Discussion 35 04-19-2018 11:46 AM
Replaced WIX with Mopar fuel filter tersejr 4th Gen Powertrain 16 06-17-2015 04:21 PM
Easier Oil Filter Removal Cacciatore 2013-2018 General Discussion 64 12-16-2014 01:08 AM
budget air filter upgrade cumminsrulez 94-98 Performance Parts Discussion 4 09-24-2013 06:46 PM
