A/C Liquid Line Question - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 06-06-2018, 02:15 PM Thread Starter
krashDH's Avatar
Alright so I wanted to ask a quick question about the liquid line running under the passenger battery tray.
Preface to why I'm doing this, my condenser had a pinhole leak from a puncture and I lost pressure obviously from that.
Prior to this, the A/C blew cold, everything worked as it should.
I ordered a new condenser as well as a new accumulator/drier as when/if the system is exposed to atmosphere, it's good practice.
I've also read about the liquid line replacement in this scenario as well, but it mainly seems that this is replaced if a compressor grenades or there is a blockage to the system. I have no such issues and it was working fine before all this.
Am I ok to stay with the current line that's in there or do I need to replace? Can you remove it without taking the battery and tray out or is this a necessary thing to do to get er out?
I've done A/C work on the TDI and other trucks, so I'll be fine drawing a vac, adding the oil, as well as refrigerant spec by weight.
Thanks in advance!
2004.5 2500 QCSB 6sp 4x4.Exhaust,Isspro EV2 gauges,SB DD3250-6,intake, Pac Brake, BD 2-piece manifold,leveled,custom front/rear bumpers,Smarty S06 POD,Chevy tow mirror conversion, projector retrofit w/ switchback turns, SRT-10 Hurst shifter,BD short shifter kit,Filters
krashDH is offline
post #2 of 14 (permalink) Old 06-06-2018, 07:45 PM Thread Starter
krashDH's Avatar
Anyone? Figured this might get a hit
krashDH is offline
post #3 of 14 (permalink) Old 06-06-2018, 09:07 PM
tryNto's Avatar
No need to replace the liquid line under the Battery.
The orifice line is the one recommended to replace if there are any cooling issues.
I know on the earlier 3rd Gens the orifice was smaller than the later ones.
I replaced mine a couple years back and it was a noticeable improvement in the A/C.
'03 QCLB 2500 305/555 NV5600 w/ FastCoolers 3.73 4x4, Color match Lear Topper.
Smarty S-06 PoD, Edge CTS for Gauges, DPP Cool Tube w/ OEM AF Box, Baldwin PF7977, GDP MK-2 FF Kit, Pusher Intake Horn, Adj. Boost Elbow @ 30psi, OEM Fan Clutch Delete/Mod, Steering Box Brace, On-Board Air w/Horns
tryNto is offline
post #4 of 14 (permalink) Old 06-06-2018, 09:24 PM
OneBadDodge's Avatar
New orifice line, its cheap insurance. Take the line with you if you go to the dealer. They ordered the wrong one and the right part # wasn't even listed.
2006 2500 Heavy Duty Sport Quad Cab, Bullydog PMT,
Bullydog Intake, 5" exhaust,Transgo/Sonnax 48RE Upgrades, Carli ball joints and track bar.
OneBadDodge is offline
post #5 of 14 (permalink) Old 06-06-2018, 09:53 PM
BFD
BFD's Avatar
Insulate the new line. I also insulated the accumulator.. Craig
2012 CCLB 4wd dually, 3.73, 68rfe, Fass, Deleted, EFI engine/trans tuning, BD IH SXE 363/80/.91 w/ebrake, 4" turbo back/51" Quiet Tone. DD and tow vehicle.
Olde too soon... Schmart too late!
BFD is offline
post #6 of 14 (permalink) Old 06-07-2018, 10:57 AM Thread Starter
krashDH's Avatar
So I wasn't having any cooling issues, my A/C was ice cold before.
Is there any reason to replace that line if it was working great before?
Is it required to remove the battery and tray to replace it?
krashDH is offline
post #7 of 14 (permalink) Old 06-07-2018, 11:02 AM Thread Starter
krashDH's Avatar
Isn't the orifice tube part of the liquid line? I believe this is the correct one...
krashDH is offline
post #8 of 14 (permalink) Old 06-07-2018, 12:18 PM Thread Starter
krashDH's Avatar
Found this
Napa PN TEM 282522:
https://www.napaonline.com/en/p/TEM282522
Can anyone confirm if this is the correct part?
Trying to get everything ready ahead of hand. Can't really crawl around on/in the truck as I dislocated my wrist and am currently 1 handed...
krashDH is offline
post #9 of 14 (permalink) Old 06-07-2018, 01:30 PM
tryNto's Avatar
Yes, that is it. looks the same as the one I used.
You will need 2 hands to seperate those connectors.
tryNto is offline
post #10 of 14 (permalink) Old 06-07-2018, 01:58 PM Thread Starter
krashDH's Avatar
Haha yeah I figured. I enlisted my buddy to help me with some of the things I need 2 hands for. He's got the same truck as me so should go smoothly (knocks on wood)
Thanks for the confirmation
krashDH is offline
post #11 of 14 (permalink) Old 06-07-2018, 05:34 PM
no need to replace a line that isnt damaged, new orafice tube and accum are good insurance even if every thing worked well.
05,2500 reg cab,auto,4x4
carlsonr is offline
post #12 of 14 (permalink) Old 06-07-2018, 06:21 PM Thread Starter
krashDH's Avatar
The orifice tube is part of the liquid line so you can't just replace the tube, you have to replace the entire line.
I'm replacing the accumulator. The liquid line was not damaged, no debris has been sent down it.
I don't want to spend the extra coin on it if it will function fine.
Your statement is kind of contradicting, no need to replace the line if it's good, but it's good insurance to replace it...so it is or isn't necessary?
I can put that money towards another project if it's ok to leave as is
krashDH is offline
