Power doors lock not working - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 10-01-2017, 02:16 PM Thread Starter
Ok guys need some help my power doors lock not working, it started with only the two rear doors not working( Typical wires were cut) fixed that. Then it everything work fine for a week, then all of the sudden it quit working, neither the fob or switch at the door seem to unlock or lock doors, have to do it manually. What to check, fuses done check the wiring, change actuator at driver side door. help please.!!!!!!!!!
2005=3500 not stock
2005=2500 stock diezel laremie
1997 =Turbo supra 840 RWH 1.43 60ft [email protected]
franksupra is offline
post #2 of 4 (permalink) Old 10-01-2017, 09:56 PM
rghavana's Avatar
dash computer controls some door lock functions
can get more info at this thread and down load
FSMs for your truck
https://www.cumminsforum.com/forum/3r...l#post23312562
can run dash computer (EMIC) test by
truck key off press and hold trip button
turn key to on position , don't start , release trip button
gauges/lights will self test , any codes will appear
first 2 characters code, second 2 digits number of time codes appeared.
post results or search for info
04 QCSB HO Automatic
rghavana is offline
post #3 of 4 (permalink) Old 10-02-2017, 03:13 PM Thread Starter
rghavana, Thanks I did not know this test, did it and this is what it reads,
C- Code
06- 01
Od - 75
A4 - 14
post #4 of 4 (permalink) Old 10-02-2017, 09:22 PM
rghavana's Avatar
INSTRUMENT CLUSTER FAILURE MESSAGE
Fault Code
Description
Correction
01
Airbag warning indicator output circuit shorted.
Refer to the appropriate diagnostic information.
02
Airbag warning indicator output circuit open.
03
ABS indicator output circuit shorted.
04
ABS indicator output circuit open.
05
MIL indicator output circuit shorted.
06
MIL indicator output circuit open.
07
Wait to start indicator circuit shorted.
08
Wait to start indicator circuit open.
0B
BTSI output circuit shorted or open.
0C
PRNDL switch input circuit shorted.
0D
PRNDL switch input circuit open.
20
Panel dimmer input circuit shorted.
21
Panel dimmer input circuit open.
22
Headlamp switch input circuit shorted.
23
Headlamp switch input circuit open.
24
Turn hazard switch input circuit shorted.
25
Turn hazard swiitch inpot circuit open.
26
Panel illumination output circuit shorted or open.
27
Courtesy/dome output circuit shorted or open.
28
Glovebox/map lamp output circuit shorted or open.
29
Cargo lamp output circuit shorted or open.
40
Wiper switch input circuit shorted.
41
Wiper switch input circuit open.
42
Wash/beam input circuit shorted.
60
Passenger door lock switch input circuit shorted.
61
Passenger door lock switch input circuit open.
62
Passenger door lock switch input circuit stuck.
63
Driver door lock switch input circuit shorted.
64
Driver door lock switch input circuit open.
65
Driver door lock switch input circuit stuck.
66
All door lock output circuit shorted to ground or voltage.
67
All door unlock output circuit shorted to ground or voltage.
68
Driver door unlock output circuit shorted to ground or voltage.
69
Passenger cylinder lock switch input circuit shorted.
6B
Passenger cylinder lock switch input circuit stuck.
6C
Driver cylinder lock switch input circuit shorted.
6E
Driver cylinder lock switch input circuit stuck.
80
Incorrect odometer value found.
81
Remote radio switch input circuit high.
82
Remote radio switch stuck.
A0
Internal module FLASH memory checksum failure.
A1
Internal module bootloader failure.
A3
Battery voltage open.
A4
Ignition Run/Start circuit rationality check.
A5
TCCM messages not received.
A6
Ignition Unlock circuit rationality check.
A7
VIN checksum error.
A8
VIN previously stored.
A9
PCI bus internal failure.
AA
PCM messages not received.
AB
TCM messages not received.
AC
ABS messages not received.
AD
FCM messages not received.
AE
ACM messages not received.
AF
SKIM messages not received.
B0
RKE fob batteries low.
B1
RKE module communication link.
B2
Cluster mismatch.
00
Done
All Diagnostic Trouble Codes (DTC) have been displayed
rghavana is offline
