What did you do to your 3rd gen today? - Page 462 - Dodge Cummins Diesel Forum
 1359Likes
post #5533 of 5591 (permalink) Old 09-14-2019, 07:00 AM
Happy Camper
Ontario Trucker's Avatar
It's all good Chris, your truck = your way, glad it worked out
no disrespect to other members
squigi1 likes this.
Gerry
2016 white Ram crew cab short box, Viair, train horns, Amp bed step
2010 Sandpiper 345RET, 40ft 5th wheel
Ontario Trucker is offline
post #5534 of 5591 (permalink) Old 09-14-2019, 09:34 AM
Kryptic361's Avatar
got my tensioner pulley replaced and a green back belt put on. no more squeaky belt.
replaced my A/C control lights, kinda nice not having that giant black space in the center of the dash anymore at night.
also new blower motor. original had a dead spot and sometimes wouldn't turn on unless you gave it a little love tap with your foot.
now to just get out there and run my valves
last week i did #4 injector and so far ( knock on wood) the truck is running way better. no more miss and smoke on start up.
Broncowilly likes this.
Colin
2006 3500 4x4 auto 5.9
s363 turbo swap, steed speed manifold, grid heater delete,kinda built trans
Kryptic361 is offline
post #5535 of 5591 (permalink) Old 09-14-2019, 09:27 PM
TWR
TWR's Avatar
I made a few sets of cam bolt eliminators from 304 stainless and installed one set in my truck.
Gator1, Broncowilly and Kryptic361 like this.
2003 Ram 3500 6 inch lift, 2016 Laramie Limited seats and 2012 console with [email protected] Shifter, Fass 95 pump, Built 47re and mishimoto trans cooler, Srt10 hood, Smarty touch.
TWR is offline
post #5536 of 5591 (permalink) Old 09-15-2019, 12:03 AM
Gator1's Avatar
What type of Machine, and end mill did you use to machine that?
03 Dodge SHO QCLB Dually w/Custom side exit exhaust-Banks intercooler-4" side draft intake-Thuren 3.0 Argon filled Shocks-radius arms-SRW 4 link Conversion-17"methods-42" Squishy's- 4.56's-Griffin Radiator-elec fans & water pump=25.263 mpg legit.
Gator1 is online now
post #5537 of 5591 (permalink) Old 09-15-2019, 12:14 AM
TWR
TWR's Avatar
hi i have a large vmc/ cnc mill and a large slant bed cnc lathe. I used a bunch of different tools. Took about 4 hours to write the programs and make a jig to hold it in the mill. I got it down to about 5 mins each after the 4 hours screwing around, dam i wish i have a 4 axis lathe with live tools.
TWR is offline
post #5538 of 5591 (permalink) Old 09-15-2019, 12:33 AM
s10010001's Avatar
Do those green back belts stop the little chirp when you shutdown? Mine kinda comes and goes...
2008 6.7 2500 4x4 Auto 3.73
2000 5.9 3500 4x4 Auto 4.10 (sold)
s10010001 is online now
post #5539 of 5591 (permalink) Old 09-15-2019, 12:42 AM
Gator1's Avatar
OK, the reason I asked is two places I worked did some stainless work, and it was always very hard on the tooling esp the stuff that was half hard or full hard they called it. I just remember it being hard to drill and use a counter sink on it even... it was tough to machine. So I was wondering if you used solid carbide end mills.
post #5540 of 5591 (permalink) Old 09-15-2019, 02:50 AM
TWR
TWR's Avatar
hi stainless is not bad to cut but you must have the speeds and feeds and depth of cut correct or it can be hard on cutters. I try to use insert cutters most of the time as the cutter wears i can just change the insert, i don't have to buy new or regrind. I use a solid carbide end mill for the last .020 so the end mill will last much longer.
TWR is offline
post #5541 of 5591 (permalink) Old 09-15-2019, 07:59 AM
Kryptic361's Avatar
Yes mine stopped it. Now it's silent on shut down. Not that the chirp bothered me. I just run green backs on everything I can cause it's a lot stronger and thicker belt.
Sent from my Pixel XL using Tapatalk
Colin
post #5542 of 5591 (permalink) Old 09-15-2019, 05:28 PM
squigi1's Avatar
Do you have the dual climate control on your truck? If so how did you replace them cause when I did a quick search to fix mine it said I need to order the whole controller with new knobs and stuff
Chris
'06 Dodge Ram 2500 Mega Cab leveled. Built trans. 100hp sticks. EFILIVE by Gordon at ID diesel. FASS Titan 150. 10mm stroker, Pusher intakes compound kit with s475 over stock,
squigi1 is offline
post #5543 of 5591 (permalink) Old 09-15-2019, 05:45 PM
TWR
TWR's Avatar
Hi you can change the bulbs on a dual zone control but you have to take it apart and solder the bulbs in I did mine. Also if your light shines green their is colour bulb caps on them.
TWR is offline
post #5544 of 5591 (permalink) Old 09-16-2019, 12:55 AM
Broncowilly's Avatar
At Pac-Nor barreling we had a Haas five axis. Talk about an amazing machine!
https://youtu.be/c0_BR5icr-M
Diesel On, Gator1 and s10010001 like this.
Bill H.
2003 Ram 2500 4X4 Quad Cab Smarty SO6 395HP tune, Edge CTS, 4 Diamond Eye exhaust
Psalm 83:18 2 Timothy 3:1-5
Broncowilly is offline
