Dodge Cummins Diesel Forum - View Single Post - Beginners Thread - Read First!
post #10 of (permalink) Old 06-15-2010, 12:57 PM
rtc1184
rtc1184's Avatar
ok so my turbo is set up a little different then yours. i have only 1 line coming into the back of my afc. i located the 90* fitting a few inches below the air intake hose of the turbo. so can i get a 1/4 needle valve, 1/4" 90, and a 1/4" barb fitting and do the same. come out of the housing with the 90* fitting, screw the needle valve to that, then the barb to the needle valve? also how does it work? by closing it does it raise the boost or opening it? thank you!
01 24v 3500 single wheel nv5600
96 built 12v tow truck dually
06 mega cab with some goodies
rtc1184 is offline
