Dodge Cummins Diesel Forum - View Single Post - I give up / Morimoto LED Fog Light Kit
post #1 of (permalink) Old 01-26-2020, 04:11 PM Thread Starter
Suny
Suny's Avatar
Hi,
I am lost among all settings.
I was running 3 years the Morimoto XB 9006 LED Fog Light Kit.
Those were running together with a Morimoto Mopar spec 2015+ Resistor.
Never any issue, and they were running a lot.
A few month ago the Driver side died.
Funny was after checking it on the Passenger side the light was running perfectly.
Out of curiosity I also checked to run them without the resistors and they did.
Crazy stuff I thought ripped out the resistors and those fogs are running since a couple of month without the resistors just fine.
Now the Driver side died again.
I started to play as well with AlfaOBD and to my surprise the Driver side came back on again.
But this worked only a few days.
In the meantime I am not able to get the Driver side back to work.
Also not with the resistor.
If you connect plain power form a 12V battery that LED Fog light from the Driver side it runs perfect.
But not in position in the RAM.
So I thought maybe a Cable Issue.
I connected the ugly OEM fogs and the right Driver side was out as well.
Perfect I thought.
I reinstalled the OEM fogs and wanted to drop it at the dealer to let them figure out the cable issue which I assumed.
I also setback the AlfaOBD setting and damn it, the OEM Driver side came back on and is running flawless.
Anyone has a proper advice how to setup the Morimoto's properly.
Especially as we have AlfaODB available now.
Otherwise I am looking into new options as I ruined the Morimotos while getting the plastic fitting for the OEM brackets off.
Thanks,
Mike
2017 RAM 3500 Longhorn Mega Cab 4X4 SRW Cummins 6.7 Aisin 3.42 Limited Package Protection Group Cold Weather Group Power Sunroof Auxiliary Switches Stop Lamp w/Camera
Suny is offline
