Dodge Cummins Diesel Forum - View Single Post - 10 speed behind a 12 Valve. Ever seen it?
post #51 of (permalink) Old 11-24-2019, 01:35 AM
bikerz
Just ran into this thread and had a thought (happens once in a while)...you don't mention what your application is for the truck. Are you hauling all the time and what kind of weight? For all the potential modification you're talking about, although fun to do, is there a simpler path? I haul intermittently up to about 16K and hated the Getrag, especially 3-4, so when I rebuilt I went with a Southbend clutch and GearVendor OD. 'Course it required cutting the driveline, and the GV won't work in 4WD, but it works 100% better for what I do (farming mostly, hauling equipment and product). I also find it great when I'm not hauling and on the hiway, it is smooooth in 5th OD at 75mph (4.11 gears). Oh, '93 W250 with mild changes including slightly larger injectors, pump bump and turbo adjustment. As I said...just a thought.
bikerz is offline
