Dodge Cummins Diesel Forum - View Single Post - How Do I Dry Out My 6.7
post #11 of (permalink) Old 11-17-2019, 02:17 PM
URDiesel
Then drain the fluids, remove the injectors and blow out the cylinders. You'll want to lube the
cylinders so they don't rust. Then refill the oil, drain the fuel system. Soak the injectors and blow
them out. Reinstall them, add fuel and see if it will start.
2016 Laramie 2500 CC 4X4 6.7L CUMMINS
URDiesel is offline
