Dodge Cummins Diesel Forum - View Single Post - 2006 Dodge Ram 2500 5.9 Locks won't Lock
post #6 of (permalink) Old 10-19-2019, 08:10 AM
rghavana
rghavana's Avatar
Did they tell you how they diagnosed ie codes??
AFAIK, Cant just replace with good used would need to be programmed for your VIN/milieage, I would google local cluster repair shop see what they can do.
Or if you feeling adventurous can try remove cluster disassemble look for bad solder joints, repair them, which is most common issue.
04 QCSB HO Automatic
rghavana is offline
