Dodge Cummins Diesel Forum - View Single Post - Fuel Leak Under Intake Manifold
post #4 of (permalink) Old 09-20-2019, 12:35 PM
hemirunner426
5/16 if I remember right. The FSM has all those details.
Get some marine grade material. It's a real PITA to change that stuff if you have a brake booster and the original fuel filter setup.
hemirunner426 is offline
