Dodge Cummins Diesel Forum - View Single Post - Odd case of spits & sputters
post #4 of (permalink) Old 09-20-2019, 12:06 PM Thread Starter
dish_towel2000
dish_towel2000's Avatar
Originally Posted by GAmes View Post
What is your fuel pressure at idle and free reved to 2000 RPM? Concerning the "need of a rebuild" how many miles between having to add a qt of oil?
Couldnt tell you that. I put a new cummins lift pump in last month and the injection pump was rebuilt last summer, 10k miles on it.
As of rebuild its 16"@2800rpm no load. That depends on the rpm. If im cruising at 2500 rpm or higher i can prolly go 100 miles before i loose a quart. However the vacuum pump leaks and gear housing itself.
1995 2500 ctd std cab 5 speed 4x4. 18o, 20% over fuel plate, 3k gsk, s300 turbo, arp studs, 3 piece exhaust manifold.
dish_towel2000 is offline
