Dodge Cummins Diesel Forum - View Single Post - What to do..?
Thread: What to do..?
post #4 of (permalink) Old 09-10-2019, 07:22 PM
Clunk
Clunk's Avatar
I went with the Edge Drag Comp and connected the pump wire (in the instructions).
If you like messing with modules and trying different "tunes", the Quadzilla will make things happen according to many here who I appreciate their opinions.
This is the place to start and you'll find out whether your trans can handle the additional 100hp.
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is offline
