Dodge Cummins Diesel Forum - View Single Post - starter rebuild question
post #8 of (permalink) Old 08-28-2019, 01:50 AM
bigfish95971
"New battery", only one? What is up with that? When some body else cranks if you get an injector to SQUIRT, not dribble, close it while cranking and squirting. Once one or two squirts and you close it it should start to fire, then the others should come online. If not squirting good or no more than one will you likely have a bad VP44 if you are getting fuel to it and Cranks sensor is working..
bigfish95971 is online now
