Dodge Cummins Diesel Forum - View Single Post - Rear diff oil?
Thread: Rear diff oil?
post #7 of (permalink) Old 08-23-2019, 10:47 AM
KATOOM
KATOOM's Avatar
I run RP only because it was readily available to me at the time and it was full synthetic and came in the viscosity I was after. Been running it for years and I often check the diff cover magnet for debris, and there's none.
That said, someone I know ran Valvoline full synthetic and they never could stop the limited slip from chattering. Was so annoying they swapped it out for conventional fluid and problem went away.
I dont think I've ever read or heard of anyone having differential problems because of the fluid brand they used. Lack of maintenance, abuse, and contamination are generally the cause of such things. So I agree...run whatever brand you want as long as it meets the specs for your application.
KATOOM is offline
