Dodge Cummins Diesel Forum - View Single Post - DEF fluid gauge accuracy
post #8 of (permalink) Old 08-20-2019, 09:11 PM
hooked55
hooked55's Avatar
Originally Posted by Jeremyw81 View Post
Thanks for all your tips. Yes, I will wait until it's at half or less next time and not even worry about the extra 2 or so gallons. I'm in FL so that'll suck if the fluid goes bad from the heat.
I pull a 5th wheel every other month, does def fluid burn faster when towing heavy loads? About 13k lbs
Yes it uses more def when towing, but not a huge difference. Have also heard others say if the def is weaker due to heat or age it will use more also. Some of us that donít put many miles on need the Chemists to come up with DEF stabilizer like what Stabil does for gasoline. Maybe it already exists, anybody?
2014 2500 Laramie Crew, short bed. 2014 30í 10k Timber Ridge TT, Nascar Nut.......
hooked55 is online now
