Dodge Cummins Diesel Forum - View Single Post - 24v tuners
Thread: 24v tuners
post #5 of (permalink) Old 08-16-2019, 01:06 AM
Syco67
Syco67's Avatar
I've run the Edge EZ, Edge Comp and currently run an Edge Juice CTS tuner. They are all good tuners depending on your budget and power goals. I used a Smarty S03 for a bit as well. If you have the time and skill, the Quadzilla Adrenaline will net you the best results. It allows you to tweak almost every aspect of the VP44 pump. I ran one for awhile but I was having a bunch of connection issues and have very little patience for mechanical things that don't work as they should. I had lots of help in trying to figure it out but in the end I gave up and went back to an Edge. That being said, I certainly don't try to talk people out of trying it. If my current Edge ever craps out, I may try it again someday.
2001 Ram QC SLT 4X4 5.9/AT(Built) BHAF, Pusher, FASS150, 4" DP, 5" Aussies, built transmission, GS gauges, steering brace, EJWA-CTS2, BD Stealth cover, turnbuckle mod, Fire Truck horn, 4th gen tow mirrors, 3rd gen brakes, switchbacks, high/3cyl switch.
Syco67 is offline
