Dodge Cummins Diesel Forum - View Single Post - Dash panel lights and rear parking sensor light stays on while truck is not running
post #2 of (permalink) Old 07-05-2019, 06:53 PM
Ltngdrvr
Ltngdrvr's Avatar
Originally Posted by Vanden77 View Post
Newbie here, just purchased a 2013 ram 3500 Laramie with the 6.7cummings turbo. The panel ights on the dash where they highlight the speedometer, tachometer, def gauge, and fuel gauge stay on after the truck is off and door is shut tight. Also the rear parking sensor light (it works correctly) stays on at the same time in the cab.....I've tried disconnecting the battery for 6hrs and reconnected with still the same issue. Any ideas would be greatly appreciated other than going to shop. Thank you!
Well, see, the problem is you got the truck with a 6.7cummings turbo, if you had bought the truck with a 6.7 Cummins engine, then you wouldn't be having this issue.
The panel lights will stay on for a while after shutdown and closing up the truck, when the computers go to sleep the dash should shut down as well.
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is offline
