Dodge Cummins Diesel Forum - View Single Post - What is torque spec for drag link?
post #14 of (permalink) Old 06-19-2019, 12:37 PM
Mike Wood
Yep, I found the table above and used some simple math to use a crows foot to torque mine down. The nut on the passenger side of the adjust sleeve came loose on mine. I cleaned the threads out with some IPA, applied red loctite, and torqued her down. Been fine for over 5k miles so far. Mine came loose with around 55k on the truck.
Sure beats some tech slapping on some booger welds...
2016 Ram 2500 Laramie Crew Cab 4x4 - MM3 w/Anarchy Tuning & Full Deletes
Mike Wood is offline
