Dodge Cummins Diesel Forum - View Single Post - Trans Temp Management
post #12 of (permalink) Old 06-18-2019, 08:11 PM
Eric-07
Eric-07's Avatar
The pan is a good place to monitor as it will let the sensor be submerged in the fluid and give you a good representation of what’s going on.
Some guys put a sensor in the hot line which will show high temps because it’s right out of the converter and before any of the coolers. Some might put it in the return line which should show a nice cool temp being after the coolers but before it goes back into the trans. In the pan IMO kind of tells “the whole story” if you will.
2007 5.9 MC - AIRDOG, AIRLIFT, ARP, AUTOMETER, BLUE TOP, BMS 100's, CPP 103# SPRINGS, DRIVESHAFT SPECIALIST, 62/475, EXERGY 10mm, EFI LIVE, POWER DRIVEN DIESEL TRANS
, MBRP, MOTOMETAL, NITTO, PRO COMP, SUPERGLIDE 3600, SYNERGY, THUREN,FUZION 5'R
Eric-07 is online now
