Dodge Cummins Diesel Forum - View Single Post - Trans Temp Management
post #5 of (permalink) Old 06-18-2019, 12:29 AM
Eric-07
Eric-07's Avatar
If your seeing those temps from the edge alone and not an actual sensor you have zero issues to worry about. The edge gets its data from the transducer which is internal of the trans. An actual sensor in the pan reading those temps is really nothing to worry about either. (Sensor in the actual hot line will read higher then what your seeing now.)
When I had a cts it would read ~40* higher then my actual pan temp.
Get a real sensor in it somewhere before you worry about what you’re seeing.
2007 5.9 MC - AIRDOG, AIRLIFT, ARP, AUTOMETER, BLUE TOP, BMS 100's, CPP 103# SPRINGS, DRIVESHAFT SPECIALIST, 62/475, EXERGY 10mm, EFI LIVE, POWER DRIVEN DIESEL TRANS , MBRP, MOTOMETAL, NITTO, PRO COMP, SUPERGLIDE 3600, SYNERGY, THUREN,FUZION 5'R
Eric-07 is offline
