Dodge Cummins Diesel Forum - View Single Post - trasnmission or torque converter rattle 4th & above
post #1 of (permalink) Old 06-17-2019, 06:59 PM Thread Starter
locopilot750
locopilot750's Avatar
Been to the dealer twice for this, nothing found. At first they thought it was a heat shield vibrating against the fuel tank. When it shifts into 4th gear and above, at about 1,000 rpm, with no positive or negative load, I am getting a "corn sheller" sound in the TC or tranny. Won't do it until 4th gear then same in 5 & 6. Truck is a 17 2500 4x4 with 30k miles started doing this about 25k or so. Annoying as hell, and it sounds like something that will get worse before it gets better. Makes the same sound in 4 wd or 2wd, so probably not the transfer case, Any ideas ?
2017 Laramie 2500, Short bed crew cab, 4x4 auto, solid Flame Red, Brown & Light Frost Beige interior w/Buckets. Air suspension.
locopilot750 is offline
