Dodge Cummins Diesel Forum - View Single Post - Truck randomly dies, then starts fine.
post #32 of (permalink) Old 05-23-2019, 11:52 PM
hemirunner426
Originally Posted by Guss101 View Post
I donít know if itís original or not, I would think so itís got 430,000 plumbers on it. Itís out of a 97 automatic so a 180 pump if Iím correct.
180 pump would be correct. I'm assuming you mean 430,000 miles?
You say it's random? It runs poorly one minute then it clears up? Does it do it cold? After sitting awhile?
Sent from my LG-H932 using Tapatalk
hemirunner426 is offline
