Dodge Cummins Diesel Forum - View Single Post - truck pulls to the left even after alignment
post #9 of (permalink) Old 05-23-2019, 05:54 PM
05PowerHouse
05PowerHouse's Avatar
Sounds like a worn caliper. I just did a full brake job on my truck due to a sticky caliper on the passenger side. As far as the deteriorated line, you would know if that was your problem. When you hit the brakes and you get a hesitation before the truck starts to break. That's an indication it's the line. You will also get a stiffer than usual brake peddle.
| Firepunk HP-T | Firepunk Comp 2 | GDP Fuel-Boss | T&C 10mm | Ducky 63% | Billet S400 | GDP Air-Boss | Stud's | Rods | Springs | Gauges |
770HP 1150TQ ( Conservative Tune )
05PowerHouse is offline
