Dodge Cummins Diesel Forum - View Single Post - Boost #ís with arp head studs and 60 lbs valve springs
post #6 of (permalink) Old 05-23-2019, 05:29 PM
DMan1198
Ducati M.
DMan1198's Avatar
Originally Posted by WillM View Post
Question has been asked a million times, and there's not an answer.
Indeed there isnít. My mess did 50psi boost, 73psi drive pressure, and 13-1400*egts with stock head bolts, and stock valve springs without any issues. Only reason I say did is I toasted the trans, and by the time I get it back on the road it might have a different setup on it.
Jaeger-12 ram 3500, CCLB, 68rfe, 2" lift, 5" tbe, steed, s476, MM w/MCC, OD, ISSPRO factory match, ARP 625's, Hamilton 103's/extreme duties, T/Rex traction bars, mag hytec trans pan,
The Roo Hunter- 93 w250, g360, np205, 4" lift, custom 3/8" bumper, Hellman sump, raptor 100, dual filters, ddp stg 3's and pin, steed, modded hybrid wh1c/hx40/s467fmw compounds 4" tbe, autometer cobalt series.
The Huntress- 02 VW Jetta tdi, 5 speed, egr/muffler delete, 11mm ve, gt1749v, ISSPRO factory match.
click here for Instagram:
DMan1198 is offline
