So my 05 pulls to the left even though according to the spec sheet from the alignment shop its dead on within spec. I have done the 4th gen steering linkage upgrade, new dampener, new track bar bushings, Dodge Offroad Brace, and new Nitto Ridge Graps. Truck still pulls. Not drastic like jerking the wheel out of your hand or anything but if I am in the right lane and let go of the wheel it will pull up the pitch grade and cross the center line. To keep it straight I have to keep the wheel slightly to the right and frankly its annoying. I have the spec sheet at home Ill post the measurements when I get home for reference. Any thoughts on what it might be that's causing it to keep pulling like that?
Believe it or not pulls to the right when you really stand on the brakes. I thought about that as well but both wheels and hubs don't get hot like a sticky caliper would make them. Ive had to replace both rears because they stuck within the last year
Sounds like a worn caliper. I just did a full brake job on my truck due to a sticky caliper on the passenger side. As far as the deteriorated line, you would know if that was your problem. When you hit the brakes and you get a hesitation before the truck starts to break. That's an indication it's the line. You will also get a stiffer than usual brake peddle.
Yea pedal pressure is normal and zero hesitation just pulls to the right when you stand on the brakes. I'll get a pic posted of the alignment sheet tomorrow morning
My truck was doing the same and I threw part after part after part at it and it still had the left pull. Turned out someone had put adjustable ball joints in and had the driver side adjusted wrong. Had the truck aligned twice and the alignment guys never mentioned it and the spec sheet didnt show it.
So taking it to them this afternoon and going to have them set it to the Thuren specs and make sure the higher caster is on the driver side not the passenger to try and "Cross caster" it to take the left pull out of it. Caster I can do minimal changes to myself at home so that I am not totally worried about but I'm going to make sure they set total toe to as absolutely close to ZERO as they can. Right now its set at .2* total toe
Well after taking back to Firestone and telling them to adjust to the Thuren specs its damn near perfect. Could possibly still use a little more cross caster but I'll deal with that when I put control arms on it. At the moment if your in the right lane shell drive straight down the road, left lane you have to keep the wheel slightly right due to the road pitch but it's much better than it was for sure.
I had a bad belt on a tire that caused me to pull to one side. A really good tire guy caught it. Take your spare and change left front tire and drive it. If still there do the right tire with the spare.
Good idea above about rotating your tires. You might want to swap the two front tires around and then drive it. Some radial tires will cause pulling and directional tires can be even worse.
Problem is my spare is a smaller size, havent swapped it to the right height tire yet, and the ridge graps only have about 1000 miles on them so dont think itd be a bad tire
heh. I had a real bad pull when one tire had 4/32s and the other was replaced and with a Dura Grappler and had 16/32s… made a huge difference.
