Dodge Cummins Diesel Forum - View Single Post - 2006 TIPM AC Output Shorted
post #3 of (permalink) Old 05-20-2019, 08:11 AM Thread Starter
Daves06Cummins
Thanks for the feedback.
Yesterday I measured ECM C2/10 input to TIPM Trigger Signal, ECM is to supply a ground to TIPM when the AC Console switch is illuminated and found it at 12.06vdc back probing the Light Blue/Orange conductor. I tried to cycle the AC switch light On/Off with key On, Blower Fan On, and then tried with engine running with same setup. No Change voltage was constant at 12.06vdc. I am going to see if there is local shop that has a DBIII scanner and see it can reflashed. If it is truly Shorted then I will replace TIPM. I bought this truck with 12,000 miles and have never had an issue with the TIPM, until now. I will post the results found.
Again thanks for input.
Dave
Daves06Cummins is offline
