Dodge Cummins Diesel Forum - View Single Post - 2500 max rpm
Thread: 2500 max rpm
post #6 of (permalink) Old 05-14-2019, 02:14 AM
hemirunner426
Originally Posted by pa coal roller View Post
Idk what it is I need a guage. I did upgrade the spring in the lift pump and have a adjustable over flow valve. Have all new fuel lines.
It doesn't matter if it is new or has 600,000 miles on it. To understand a problem requires collecting data about the problem. Get a gauge and we'll start there.
Sent from my LG-H932 using Tapatalk
hemirunner426 is offline
