Dodge Cummins Diesel Forum - View Single Post - 2500 max rpm
Thread: 2500 max rpm
post #5 of (permalink) Old 05-14-2019, 02:10 AM
nSaEvAyL
This is why I have stayed off this site for the last 6 years. How do you have almost 1400 posts and been a member on here for almost 10 years and proceed to ask a question worded this poorly?
This is right up the line with "why won't my truck start?"
When did you add your GSK?
Did you correctly install your GSK with the right stud clearance? Probably not..
What is your fuel pressure?
Have you changed your fuel filter?
98 12v SC 4X4 114K Miles, A5K, SDX 5X18, 4K GSK, KDP, Custom VB, Deep Pan, Peak Diesel IC/B, Devils Own W/M, Head Studs, 60lb VS, 2095 Rack Plug, Barrels moved, Guages (EGT, Boost, Trans Temp), Timed 22* http://s1057.photobucket.com/albums/t398/lwilde13/
nSaEvAyL is offline
