Dodge Cummins Diesel Forum - View Single Post - Strange Trailer Light Problem
post #2 of (permalink) Old 04-29-2019, 11:35 AM
MDSWA
MDSWA's Avatar
Here's a link to the Newbies Guide for your new truck. It contains a Factory Service Manual that may help your to troubleshoot your electrical issues.
https://www.cumminsforum.com/forum/3...you-truck.html
Have you tested all functions on the 7 pin plug with a test light to make sure everything is working on the truck? That would isolate the problem to the truck vs the trailer. Bad trailer grounds and corroded sockets, etc., can raise havoc with trailer lighting. I had a similar issue with my 05. Everything worked except the left turn signal signal on the trailer. After much troubleshooting I ended up having to replace the TIPM as it turned out to be a non-serviceable bad relay.
MDSWA is offline
The Following User Says Thank You to MDSWA For This Useful Post:
smeek (04-29-2019)
