Dodge Cummins Diesel Forum - View Single Post - Starting a Long Sitting Truck
post #21 of (permalink) Old 04-20-2019, 12:43 PM
9297oldram
9297oldram's Avatar
Originally Posted by daword2011 View Post
Yeah I removed the quick connects at the engine bay and it looks like I can slip rubber on to them and just use a hose clamp to keep it from leaking temporary. Now, to drop the tank or lift the bed is my next challenge haha
Sent from my LM-G710 using Tapatalk
That's what I did on mine and was still holding for 6 years when the truck died of cancer.
I found that if you removed the drivers side bed bolts and just loosened the passenger side bolts and the fill tube from the bedside you can lift the bed high enough to get to the top of the tank.
If you have 2 floor jacks it's easy to drop the tank also, hardest part would be getting in there to disconnect the fuel lines.
9297oldram is offline
