Dodge Cummins Diesel Forum - View Single Post - CP3 Connection Question
post #7 of (permalink) Old 04-17-2019, 11:08 PM Thread Starter
Dudeonthenet
Originally Posted by cerberusiam View Post
Don't need another fitting, just plumb the FASS\AD to the inlet of the factory fuel filter housing and you are done. With that in the way then just use the best filters possible on the FASS\AD and get a new tank canister with a 1/2 lines form GDP. If you live or travel in any cold weather get the LP with a fuel heater option and install it.
Thanks, cerb. So you mean plumb into the supply line from the fuel tank, right before the OEM filter canister mounted lift pump and let the AirDog push the fuel through? And then can you use the OEM lift pump as a back up to the AirDog?
04.5 QCSB 4x4, 156K, 2nd Owner, Pacbrake, Airbags with onboard compressor, CTS Insight gauge w/Backup Camera, Smarty Jr tuner
Dudeonthenet is offline
