Dodge Cummins Diesel Forum - View Single Post - 3rd Gen Chase Truck Build
post #33 of (permalink) Old 04-14-2019, 07:20 PM
smelonas
smelonas's Avatar
Gordon at innovative is real responsive. Phil at anarchy also has some slick tunes. Thats who I would use.
As far as 600hp. Stock fueling has only been able to do about 570 or 580. Timing gets off when you try and set pulse width long enough and smoke becomes present. 50hp injectors will compliment your turbo well. BBi without a doubt. Dont waste your time anywhere else. Your truck will run it's best with BBis.
A triple disc is a must obviously. Dan Vallance at valair clutches will get you set up.
I assume you have added a steering box brace and all that? You are going to need one..
Also, if you havent thought of it, axle truss. The 925 AAM axle is a partial scam.. it's not a bad axle, it just cant really be serviced like a dana can be.
Sent from my SM-N950U using Tapatalk
1994 Buick Roadmaster Sedan 'Betsy' LT1-4L60E, Every Option Good Old Fashioned Lead-Sled
2007.0 Ram 2500 MCSB Laramie Every Option - ATS S3|FASS 150|DDP 50HP|S&B Intake|4"TBE|CTS2|EFI
smelonas is offline
