Dodge Cummins Diesel Forum - View Single Post - Starting a Long Sitting Truck
post #15 of (permalink) Old 04-05-2019, 03:02 PM
9297oldram
Moderator
9297oldram's Avatar
Originally Posted by daword2011 View Post
Taking a quick look (online search) it appears that the FSS has 2 connections on it. One black, one blue fusable link. Assuming the blue is the signal from the ignition and that is the one to provide +12v to in order to get the FSS to open?
If I remember right the blue one is the key on wire, the other wire is power for the KSB which hangs on the side of the IP and isn't needed on the intercooled engines. The KSB advances the timing for cold starting, I never had a issue with cold starting and mine has been unplugged for 9 years.
9297oldram is offline
