Dodge Cummins Diesel Forum - View Single Post - 3” vs 6” lift
post #4 of (permalink) Old 04-02-2019, 06:36 PM
avvblanc01
avvblanc01's Avatar
if you go to a 6" I'd recommend going to 37's or 38's for the right visual proportions. Here's my truck on a 3" Carli Dominator system with 305/70/17 tires (a 34ish" tire) and then 37/125/20 tires. Both look good, but a 37 definitely looks better! Keep in mind though that you need to have the perfect wheel specs to stuff a 37 without major rubbing, and you'll also need high clearance control arms. A 35 will fit on stock arms no problem.
CMH2007 is right that the 6" kits do cost more as they have more components, but with ether Thuren or Carli, the 6" kits provide more wheel travel than the 3." On these kits, the height is actually just a byproduct of travel increase since the only way to increase travel on a solid axle truck is to increase the distance between the axle and frame. Hope that helps!
2006 Dodge Ram 2500 by Andrew Villablanca, on Flickr
2006 Ram 2500 by Andrew Villablanca, on Flickr
Instagram:@AVVBLANC 2006 2500 qcsb 4x4: auto, yukon hubs, Fass, 2mic Cat/baldwin 5mic FWS, 20" Trail Ready wheels & 37's, Edge insight, custom retroshop, heads/tails, Carli Dominator, Amp steps, Smarty JR 1993 D350 5spd, HID projectors, 4in TBE
avvblanc01 is offline
