Dodge Cummins Diesel Forum - View Single Post - OD housing cracked/exploded 100 miles after 47RH rebuild
post #12 of (permalink) Old 02-12-2019, 05:15 PM
blackDOHC
blackDOHC's Avatar
Originally Posted by Cheatham View Post
Also the shop could've swapped the overdrive unit from an re from a v8, they will interchange and it's a cheap way to do a rebuild, But there is a big difference in the internal of a v10 and diesel overdrive unit. Unless you check for yourself you may never know.
I never knew this until I was rebuilding the Jasper trans that came with my truck. Different clutch counts and a different backing plate if I remember correctly.
1997 ECLB - 5" Diamond Eye straight pipe - ISSpro Trans temp/EGT/Boost - AFC Live - boost elbow - 191s - Built trans - BHAF - ARP 425s - PSC SG852 - 315/75/16
blackDOHC is offline
