Dodge Cummins Diesel Forum - View Single Post - OD housing cracked/exploded 100 miles after 47RH rebuild
post #11 of (permalink) Old 02-12-2019, 02:53 PM
Cheatham
Cheatham's Avatar
Also the shop could've swapped the overdrive unit from an re from a v8, they will interchange and it's a cheap way to do a rebuild, But there is a big difference in the internal of a v10 and diesel overdrive unit. Unless you check for yourself you may never know.
07 6.7 QCSB 2500 deleted. Smarty jr, straight piped sold. 2001 SRW QCLB sold. currently have 94 rc 3500. auto/trans, #5 plate, 4k gov. spring, gauges. straight piped. adj.o/f valve. Timing @ 17.5 new 5x12s, 024 D.V. AFC Live, Plate removed.
Cheatham is offline
