Dodge Cummins Diesel Forum - View Single Post - Alfa OBD Success!
post #2 of (permalink) Old 01-17-2019, 02:50 PM
67guzzler
67guzzler's Avatar
NICE! So far I have:
  1. Enabled LED for license plate bulbs (can see via backup cam photo sensor they're not cycling anymore)
  2. Enabled LED for fog lights bulbs (can see via phone photo sensor they're not cycling anymore)
  3. Enabled DRL and set to USE LED turn signals (have factory projectors -- very bright). Played with FOGS as DRL but went with turn signal LED's as DRL's because I can run park lights (DRL's stay on) to fire up the LED fogs and and have the best of both worlds...
  4. Set my tire thresholds to 35 PSI (down from 80 / 60 from the factory on my 2017 2500) as I like to run around 45 PSI
  5. Disabled FOG LIGHT DROPOFF so they stay on with high beams
  6. Enabled Global Down. Global up doesn't seem to work but I read that with https://zautomotive.com/product/tazer-ram/ aka "Tazer" plugged into OBD II 24/7 you can have the equivalent. I'm not so interested in that.
I was asked by a friend if this was possible: Set it so backup lights will illuminate upon unlocking the doors
I didn't see anything I could change for this. Asked on ramforum and was told it might not be an option.
Still searching for more things to tweak. This is quite awesome.
-Guzzler
PS: I'm using this (ANDROID and WINDOWS ONLY) for my OBD II Bluetooth Adapter and it works great: https://smile.amazon.com/Vgate-Scann.../dp/B075R62FTH
2017 2500 Crew 4x4 Laramie 6.4L HEMI 66RFE w/4.10
PRIOR: 1994, 1996, 2004, 2005.5, 2010 and 2013 2500's. ALL Cummins.
If someone is nice enough to post a truck-related pic,
I'm more than happy to click a "Like or Thanks."
67guzzler is offline
The Following User Says Thank You to 67guzzler For This Useful Post:
2500/6 (01-18-2019)
